Go to Post The animation is just a pretty tool to help outsiders understand the game; the manual is for me, the animation is for my grandmother. - JVN [more]
Unread 04-02-2011, 01:35
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Update!
Dont know if it's really even worth mentioning but the LV update has been updated to 3.1
not sure what the differences are just thought i'd let you guys know
Expect the best, Prepare for the worst
Unread 04-02-2011, 08:11
Re: Update!
That was released January 8, almost a month ago. Old news ?
Unread 04-02-2011, 09:53
Re: Update!
Update 3.0 was released January 8, Update 3.1 was released yesterday. NI didn't update the release date on their website
Inside the zip file is a readme that says what they changed.
Make sure you install the v27 cRIO image that was included with the update.
Unread 04-02-2011, 10:11
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
Re: Update!
According to http://joule.ni.com/nidu/cds/view/p/id/2261 the FRC LabVIEW update was 3.1 back on January 8th... and I don't see any new information on the Software Updates page: http://www.usfirst.org/roboticsprogr....aspx?id=18758
Unread 04-02-2011, 10:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Update!
Was this officially announced somewhere? I thought I was paying close attention to the information flood
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 04-02-2011, 10:49
Re: Update!
If you are connected to the internet when you start LabVIEW, There's a release announcement in the upper right hand corner. Updates for all three languages were released yesterday.
I'd guess it will probably be mentioned in today's team update.
Unread 04-02-2011, 11:00
Re: Update!
That is a bit unsettling.
Unread 04-02-2011, 12:27
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Update!
It's up there now.
-- Marshal Horn
Unread 04-02-2011, 12:32
Re: Update!
Originally Posted by kamocat View Post
It's up there now.
It was up there before.
But they didn't update the release date.
It still says
Available Downloads:
Standard Download: FRCLabVIEWUpdate3.1for2011.zip (100 MB)
Download Language: English
Product Line: Academic
Version: 2011
Release date: 01-08-2011
Software type: Application Software
Operating system: Windows
Unread 04-02-2011, 20:28
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
Re: Update!
Bug Fixes and Updates
The 3.1 update includes the following bug fixes and updates:
* Allows your robot to communicate with the FRC Field Management System.
* Allows you to build applications using the licensed IMAQ VIs.
* Enables the Data Entry page of numeric controls to update properly in LabVIEW 8.6.1.
* The NI Example Finder includes examples for Vision and for the linear encoder sensor.
* The default value of the LED toggle rate global variable in the Robot Global Data VI changed to a 10 millisecond loop delay.
* The Begin VI in the FRC cRIO Robot project includes the DIO Open VIs so that IR sensors work as expected.
Known Issues
The 3.1 update includes the following known issues. This list might not include all known issues for this update.
* When you use more than one encoder, the rate indicator does not update for all encoders. To avoid this behavior, write your own encoder rate code.
* LabVIEW hangs if the CONSOLE OUT switch on the CompactRIO device is on while you use the black Jaguars motor controllers with the CAN bus.
* The LabVIEW Help does not contain detailed help for the CAN API, the MotorControl Enable VI, and the MotorControl Disable VI. Visit the NI FRC Community Web site to access available FRC training material.
* The GetSpeed VI on the MotorControl VIs palette changed to the GetOutput VI, but the LabVIEW Help does not reflect this change.
Unread 04-02-2011, 21:23
AKA: Jon
Re: Update!
Known Issues
But all of this stuff includes the 3.0 update not the differences between 3.0 and 3.1 which is in the file
Unread 05-02-2011, 02:44
Acarid Acarid is offline
<3 Nested Clusters
FRC #2521
Acarid is an unknown quantity at this point
Re: Update!
Do we need to create a new FRC cRIO Robot Project after applying this update or are we still good?
Unread 05-02-2011, 06:25
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Update!
No, all of what you quoted is new to the 3.1 update. The only thing wrong in the readme is that this one item:
"LabVIEW hangs if the CONSOLE OUT switch on the CompactRIO device is on while you use the black Jaguars motor controllers with the CAN bus."
has actually been fixed.
Doug Norman
Unread 05-02-2011, 06:26
Re: Update!
No, your existing project will work. But you do need to reimage the cRIO first.
Doug Norman
Unread 05-02-2011, 06:30
Re: Update!
Sorry about the release date not being changed. We'll fix that. This is a required update that you need.
Doug Norman
