Go to Post Might change next year. Read the manual then too. - Billfred [more]
Unread 04-02-2011, 08:28
Re: Toggle switches to Analog board?
It should look like this...
Unread 04-02-2011, 09:21
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
If I am looking at this correctly, does this mean I can't use a SPST switch to do what I want to do? I need a SPDT?
Unread 04-02-2011, 09:58
If you are going to the analog board, it does not have pull up resistors so you have to use the SPDT to switch between +5 and zero volts. If you use a digital input, the pullup would allow you to simply open or close a connection to the common to give two states.
Unread 04-02-2011, 10:11
Sorry, Al, but I have to disagree. If you put a 10k pullup resistor between the analog signal and +5 power pins, a simple SPST switch between signal and ground will give the desired results. The schematic Darren posted is exactly how I would do it.
Unread 04-02-2011, 10:16
JamesBrown JamesBrown is online now
Back after 4 years off
FRC #5279
Attached is a picture for SPST (Al, please correct me if I am wrong but this should give him two states (Closed =0v Open=~5v) using a Single Pole Single throw switch on the Analog inputs which seems to be what he wants to do.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 04-02-2011, 11:11
Yes, You guys are right. I have to stop answering these questions while I am working on interfaces here. Alan, can you add something about programming so that switch bounce doesn't confuse the readings?
Unread 04-02-2011, 11:38
Switch bounce would affect switches connected to a digital input at least as much as it would analog inputs. Most of the time, the programming is going to be such that it simply doesn't care whether the switch gets detected several times in quick succession.
For reading a switch on an analog input, the WPILib "analog trigger" function is what you want. That rejects glitch-type noise as part of its implementation.
FRC #5279
Edit: Looks like I need to type faster if I am going to post in the same threads as Al and Alan. But what I posted may still be usefull so I will leave it up.
I am not Alan but I should be able to help here any way. To debounce a switch in software what you want to do is ensure that the press that was detected was a true press, not just noise or bounce. The easiest way to do this is once a press is detected start a counter, if the counter reaaches a certain value (10ms is probably acceptable for FRC Applications) then acknowledge that the switch is pressed. If the switch is released before counter times out the reset the counter and ignore the bounce.
Psuedo Code
Create Counter- Initialize to Zero
Assuming Switch sampling occusr every ~1ms
If (Software_representation of switch = not-pressed)
If switch is not pressed
Reset Counter
Set Software representation of switch to not-pressed
else (switch is pressed)
increment counter
end if
if counter > 10
Set software representation of swtch to pressed
end if
Then you can reverse the switched/not-switched cases for then the butto is pressed if you need to detect the release as well.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 04-02-2011, 17:58
sircedric4's Avatar
AKA: Darren
Cool discussion, I am happy I can use my SPST switches. I already had a bunch purchased and laying around. I also appreciate the pseudocode. Thanks again.
Unread 04-02-2011, 18:23
Darren,
Sorry I led you down the rosy path earlier.
