Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 04-02-2011, 08:53
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Freelin-Wade FlexCoil
Good day. We're looking to get some compressed air up our elevator. I was looking around online and found these sweet FlexCoil hoses made by Freelin-Wade:
http://www.freelin-wade.com/coiledtu...c-1_27_30.html
Thing is, it doesn't seem that you can order these hoses online through Freelin-Wade. Anyone know where I can order them from? Or something similar anyways? We're hoping to reach 10-12 feet at the most.
FRC 2656 | FTC 5526 | VEX 9656
Unread 04-02-2011, 08:55
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Freelin-Wade FlexCoil
Here's a similar product: http://www.automationdirect.com/adc/...e_(PUR)_Tubing
Automation Direct also ships pretty quickly.
-Dustin Benedict
Unread 04-02-2011, 09:05
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We bought some from McMaster back in 2008....
http://www.vandenrobotics.com/plogge...348resized.JPG
Here's their product...
http://www.mcmaster.com/#5612K53
Each one comes in a pair (red and black) which is nice if you do dual acting cylinders. We had to run two sets of them back in 2008 to operate two different cylinders. The only draw back was how stiff there are to work with (but what do you expect if it self coils). They come with ends that we just cutoff.
Unread 04-02-2011, 09:09
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
You can take your hose from the kit, curl it around something round, apply a little heat and make your own.
Unread 04-02-2011, 09:12
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Thanks everyone! I'll sort through these suggestions and see what works best for us.
Unread 04-02-2011, 09:19
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
We got our coiled tube from
http://protubing.com/
I believe that is what was in the "Where to get more" file on the FIRST website. It was easy to browse and they had it delivered within a couple days.
Unread 04-02-2011, 10:26
KathyW KathyW is offline
FRC #1541 (MidloCANics)
KathyW is an unknown quantity at this point
We are also looking at getting some of the FlexCoil for this year's robot, however the rule from the competition manual states that:
<R66> D. Additional 0.160” inside diameter pneumatic tubing functionally equivalent to that provided in the KOP, with the pressure rating clearly factory-printed on the exterior of the tubing,
However, the Freelin-Wade coil doesn't have this printed on it, nor do any of the other sources that I've checked out. Any ideas?
Unread 04-02-2011, 10:35
thefro526's Avatar
Mentor for Hire.
From what I can see, the Nitra coiled tubing that Automation direct does have specifications printed on it. The black tubing seems to have the clearest markings if the pictures are accurate.
-Dustin Benedict
Unread 04-02-2011, 13:00
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Actually, we got some grief from inspectors about doing exactly that back in 2007. There was a concern that the heat would degrade the tubing causing it to fail at a lower pressure than rated. YMMV...
Unread 16-02-2011, 17:55
TubeGuy TubeGuy is offline
TubeGuy is an unknown quantity at this point
I'm the marketing manager at Freelin-Wade. For five years now, we've donated the tubing that came in the KOP (this year's donation was 23 miles worth!). In addition to the tubing that came in your kit, FIRST teams can purchase any of our tubing, including custom coils, at a 50% discount. We'll print the FIRST specs on the tubing and turn it around faster than anyone. Because we're partners with FIRST, you can count on us getting it right. Go here to get the discount: http://www.freelin-wade.com/first.htm
