Go to Post The unlived life is not worth examining; the unexamined life is not worth living. - Sage-Theory6 [more]
Unread 04-02-2011, 12:30
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Jaguar Screw terminals
I was told by my intern at work that there is an issue with removing the screws on the terminals of the gray jaguars and that they should only be loosened and use u shaped on ring connectors on them?
and that if they are removed, metal shaving get into the terminals and could cause problems.
any experience or info on this?
Unread 04-02-2011, 12:42
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Jaguar Screw terminals
This is indeed true unless it has been fixed on later versions. In our first year using Gray Jaguars we killed a couple this way. The Black Jaguars don't have this "feature".
If you've already done this to your Grey Jaguars but they are still functioning, I'd suggest taking them apart and blowing out any chips with canned air or an air compressor.
Unread 04-02-2011, 14:07
It's covered in the Jaguar FAQ. http://www.luminarymicro.com/jaguar
Unread 04-02-2011, 14:27
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
This is true for all Grey ones. The Grey were built for only one year, and the same captive terminals were used on all built.
This is no longer true for the Black ones. The terminals were changed to non-captive screws and so if removing a screw from a Black Jaguar, there is no debris left.
For the non-captive screws, it is recommended that you only remove one screw at a time to avoid mixing the colors and making a costly mistake later.
