Go to Post There are always going to be tough calls, and you just have to trust in your officials to do the right thing. - Jeff Waegelin [more]
Unread 04-02-2011, 12:22
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: LabVIEW Encoder not reliably returning Rate
Originally Posted by Tom Bottiglieri View Post
So, was there ever a fix for this?
There was a new LV Update released a couple days ago. LV Update 3.1 for 2011.
Does anyone know if this issue was resolved with that update?
Unread 04-02-2011, 12:23
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Originally Posted by Doug Norman View Post
I have reproduced this and believe it is a bug in our code. I suspect we may document this rather than fix it for this season for two reasons:
1. It would be a risky fix.
2. There is the work around of writing your own rate code.
Do you have a single document describing all the bugs this season?
EDIT:
The Readme describes some of them, but leaves out CAN issues.
Is there a document that shows new issues, BEFORE a fix is created?
-- Marshal Horn
Unread 04-02-2011, 12:51
I do not believe this release has a fix for this bug. I saw a post from Joe stating who would not let him fix it. He also didn't indicate whether he had really really fixed it this time, sorta fixed it, turned it into a feature, or other.
I agree there should be a known issues list along with workarounds. I'm not sure if the support forum has one. That would be the appropriate place to request one.
Greg McKaskle
Unread 04-02-2011, 13:58
billbo911's Avatar
Greg McKaskle
It has NOT been fixed in this update!
From the 3.1 README:
Known Issues:
When you use more than one encoder, the rate indicator does not update for all encoders. To avoid this behavior, write your own encoder rate code.
Unread 04-02-2011, 14:02
The readme for LV Update 3.1 (included in the zip file) lists the encoder rate issue as a known issue and suggests that you write your own rate code.
Unread 04-02-2011, 14:03
Known Issues:
Or,
"You're holding it wrong."
Unread 04-02-2011, 14:06
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Can we create these on an unused DIO slot? Unused IO pins on the one DSC we have are hard to come by.
Yes... they can on slot 6.
Unread 04-02-2011, 15:25
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Is there any reason why it worked fine last year (cRio image 20) but doesn't work this year (tested cRio image 25)?
Also - Will it care if I allocate the dummy encoders on slot 6, if I don't actually have a DIO module on slot 6?
Also again - Is it that every other encoder works, or every other encoder created works? If I were to edit the VI that assigns counters (or encoders), and told it to only assign the odd or even counters (or encoders), would that fix things?
Kettering Motorsports
Unread 04-02-2011, 15:29
billbo911's Avatar
What would be really nice is if we were told exactly what the "bug" was so that we could fix it.
I know that we can create our own code, but knowing what is wrong with the current one could help us NOT create our own buggy code.
Unread 04-02-2011, 15:52
Because the FPGA image is different than last year.
No... it won't care. And neither will you because you aren't using them.
Based on reports, it is every other encoder... so if you change the VI to assign only even encoders, then they should all work. I have not actually tried this approach so I can't guarantee that it will work, but it sounds reasonable.
We can't touch the FPGA code. It's going to stay broke.
Unread 04-02-2011, 15:55
The actual bug is most likely in the FPGA (we believe... we haven't actually debugged to find what the bug is exactly) and therefore not implemented the same way you would implement it in your code. Therefore there should be little risk of you writing code with the same problem.
-Joe
Unread 05-02-2011, 01:53
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
No one postd anything about having a lot of noise from the encodes so I figure I should ask again.....how does the signal from the encoders look? Ours looks extremely ugly. To the point where when we apply a median filer what we get out is almost half of the peak rpm being measured.
Unread 05-02-2011, 11:18
You can reduce the noise by using 1x decoding rather then 2x or 4x. This eliminates noise introduced by the phase error of the encoder.
Unread 06-02-2011, 16:29
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Even starting with zero or one?
Is the procedure to start with a dummy and then daisy-chain error out and error in to create the sequence?
