Re: Quick release bumper design
We have finished building the quick release mechanisms. We have a total of 8 on our robot 2 per side. They work amazing, we are in the process of making a cable that will allow one person to pull up on and then just slide the bumpers in.
If you space the 2 quick release brackets the same distance from the front and the back of the robot the right and left sides will be interchangeable same with the front and the back. We made the spring to be adjustable so they are plenty strong enough. We dont plan on them coming off but I will keep you all posted. Today I will post an updated video of all 8 on the robot and how we intend for them to work. |
2 per side might violate the "support every 8" rule"
How are you supporting the robot to meet this rule. It is a very nifty idea... Remember also that your fastener can't extend out beyond the wood... I hope you make this works Our team has used rivets to fasten our bumpers for awhile now... pretty quick and very sure good luck! |
Where do you go to school? I want to go there!
I assume I'm misunderstanding this. It sounds like you're riveting your bumpers to your robot...and that can't be right. Among other things, it would take forever to remove them for inspection. Please help me understand what you're describing.
I'm assuming aluminium rivets here - a bit easier to drill out than a steel rivet. |
#7
They are quicker to get on and off than bolts and nuts actually. Our whole robot is riveted in constuction... similar to the 217/148 style of construction... The school we come from is Aviation High School ...right in the middle of the land of Boeing. Rivets come natural to us... Many of our students want to go on into aero engineering... thanks!! |
#8
The 8-inch support rule says that you cannot have any missing sections of frame greater than 8". It doesn't say your bumper has to be connected every 8".
Most teams using traditional bolts and wingnuts use 2 or 3 connectors per side. |
#9
i am sure they can do it... I just want to make sure that the entire rule is considered.. Quick release mechanisms, from my experience, are not commonly as tight as standard solutions... thanks!! B |
#10
"Tight" has a bit more flexibility to it this year. 1/4" of space or less of space officially counts as supported.
#11
Okay we finally finished making all the brackets (16 because we are making two complete sets)
I, the build team captain, put another student in charge of making the brackets. However, not a single one fit so I re did them and if they are done right everyone of them fits the first time. When I get some time i will make a how-to video. Both sets will be completed by this wednesday I will keep you updated |
#12
I am concerned how quick release designs are not a violation of rules.
The hardware attached to the plywood can only protrude out from the plywood surface a bit more than 1/4" if it stays attached to the bumper. So if you then declare the fancy bumper hardware is, instead, part of your robot and not part of the bumper, then they are sticking out past the outer planes the frame, which is also a violation, plus it reduces the max size of your frame. So this seems to be a Catch-22 scenario. How is the quick release attachment H/W going to BRIDGE across both the frame and the plywood enough to strongly join them when the joining h/w can only overlap onto the frame by ~1/4"? Having only 1/4" of metal protruding from the plywood that can overlap onto the frame is not very much to work with for accomplishing an effective quick release design. Am I missing something here? BTW, even if horizontal bolts going through the frame to protrude enough to screw into flush threaded inserts, set into the plywood, are used to secure the bumpers, are the bolts considered part of the robot or the bumper? If they are part of bumper, they are a violation, and if they are part of robot they can also be considered a violation (no protrusions from robot frame can go out very much), plus they would be extending the size of robot. -Dick Ledford Last edited by RRLedford : 05-02-2011 at 21:25. |
#13
I cannot find justification for this statement in this year's competition manual. I am assuming that this interpretation came from <R07-L>, but that rule only governs how far the hard parts of the bumper may extend outside the frame perimeter and does not restrict extension of the bumper inside the frame perimeter.
#14
-Dick Ledford |
#15
Dick, you are misinterpreting <R07-L>. The rule is saying how much BUMPER-stuff can be outside the FRAME PERIMETER - it includes the noodles and fabric in "soft parts". There is no restriction on how much can be inside the frame.
