Go to Post We’ve been chasing perfection since 2003 in the hopes of catching excellence. - Karthik [more]
Unread 04-02-2011, 16:10
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
Analog Devices ADXL345 and ADW22307 Sensor Board
our team wants to use the Analog Devices ADXL345 and ADW22307 Sensor Board but we don't have any idea on how to wire them. we looked through the sensor manual but there isn't any information on how to wire them.
any help would be appreciated
thanks
austin1743
Unread 04-02-2011, 16:42
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Analog Devices ADXL345 and ADW22307 Sensor Board
http://www.usfirst.org/uploadedFiles...ual%20RevA.doc
I know that in this document, in the text it describes how to wire the devices.
Jacob
Unread 04-02-2011, 16:51
FRC #1743
thanks we have looked through that we have the accelerator wired but don't know how to wire the "Gyro" part of it...
in that document doesn't mention how to wire the gyro, unless we are misreading it
Unread 04-02-2011, 17:17
AKA: Jacob Komar
In the gyro section, there is a table
It looks something like this
|  RATE  | Temp |
|  +5V   |  +5V |
|Ground |Ground |
And it says *Pin-out as follows, in same orientation as photo above:*
Hope this helps.
(Simply hook up a PWM cable to the rate half, with the white wire in the RATE pin.)
Jacob
Unread 05-02-2011, 10:26
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
We just hooked up our gyro. The post above is correct. You hook rate up to the sig pin on your analog breakout and the + and - respectively. ( I believe that they are already in the correct order, but check to be sure). Also, unless you have a female-female PWM cable, you will have to cut and splice two regular ones. Also, I have attached some code that we are running that provides an auto-trim function using the gyro.
Unread 05-02-2011, 14:06
FRC #1743
thanks we have it wired now...
can someone help us with the java code though?
