Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
Unread 02-04-2011, 04:16 PM
roguegdi roguegdi is offline
FRC #3525
roguegdi is an unknown quantity at this point
Motor only turns one way!
The motor for our arm only turns one way, we are programming in labview if that helps.
The only way to get it to turn the other way is to change the wiring, naturally.
However, that is extremely unconventional and therefore I am in need of assistance! We are using a window motor for the arm.
Help ?
Unread 02-04-2011, 04:35 PM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Motor only turns one way!
Can you provide us with some more information? Are you using a spike, victor or jaguar to control the motor? If a Jaguar, check that both limit switch jumpers are in place - missing one of them would prevent you from turning in one direction.
Look at the LED on the spike/victor/jaguar and tell us what you see - what does it do when you turn the arm one direction, and what does it do when you try to turn it the other?
Unread 02-04-2011, 04:42 PM
FRC #3525
Limit switch jumpers, what are those?
Unread 02-04-2011, 05:03 PM
doot doot
AKA: Brandon Liatys
If wired correctly, the motor should run through a jaguar. This will allow you to reverse the polarity without physically switching the wires.
This is a jaguar:
http://team358.org/files/programming...Controller.jpg
I've also seen them in black
FRC 2495 - Hamilton West Robotics [2007-2014]
Back for 2017!
Unread 02-04-2011, 05:05 PM
Chris is me's Avatar
AKA: Pinecone
You can also use Victors - Window motors in particular work much better with Victors than Jaguars.
Unread 02-04-2011, 05:20 PM
Check out the manual on the Jaguar here:
http://www.luminarymicro.com/index.p...d&Itemid=59 1
On page 9 is a diagram detailing all of the inputs and outputs from the Jaguar, and the "Limit switch inputs" are on the bottom right. There are 4 pins there. Put a jumper connecting the two on the left to allow forward movement, and a jumper on the two on the right to allow reverse movement.
These pins allow you to hook up normally-closed limit switches so the motors will automatically turn off when pressed - for example, when an arm reaches a maximum limit. To use that feature the FIRST rules state you need to use the CAN bus instead of PWM control... however missing a jumper will prevent the Jaguar from turning in that direction.
If you aren't sure if your missing one, or if your Jaguar is hooked up correctly, please post a picture of it so we can take a look.
Unread 02-04-2011, 05:25 PM
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
In addition, what motor are you using which could make a difference and might not as well.
It's always a good Idea to post as much details about parts(like the exact motor) you are using, that could be involved with the issue so you can get a faster solution or not have to go back and check.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 02-04-2011, 06:02 PM
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
I've never heard of this before . What are you basing this on?
Unread 02-04-2011, 06:05 PM
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
http://www.chiefdelphi.com/forums/sh...ad.php?t=83973
This thread. Don't use window motors with Jaguars.
Kettering Motorsports
Unread 02-04-2011, 06:20 PM
Please elaborate?
EDIT: I read the other post linked to further down in the thread. If that person had not posted it, however, I would have no idea what you were talking about.
Unread 02-04-2011, 06:21 PM
Aren_Hill's Avatar
Build Nifty Things
We had 2 steering our 6wd swerve last year that ran just fine, so your mileage may vary.
A guy who likes robots.
Unread 02-05-2011, 12:29 AM
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
We had the exact same problem, but with the jaguar reporting a fault when we tried to run it backwards. After a while of trying to run it backwards, we started smelling ozone and declared the jaguar dead.
Apparently, it's a common problem and is just due to a manufacturing error. Unfortunately, you can't RMA gray jaguars anymore, so you're kind of stuck.
Unread 02-05-2011, 10:21 AM
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Don't use the grey ones!!! Everybody got the new black jag's in there kit this year. The black ones work alot better than the old grey ones. Here are the exact specs. http://www.luminarymicro.com/jaguar (there at the bottom of the page)
