Go to Post NEMO is a virtual organization with a virtual headquarters and virtual bank account. - KathieK [more]
Unread 04-02-2011, 14:42
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
pic: Compressor Size Comparison 4
Unread 04-02-2011, 14:45
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: pic: Compressor Size Comparison 4
that would appear to be a 095c, the mounts on our 090 are different.
2016 Central Illinois Winner. Curie Division finalist
Unread 04-02-2011, 14:47
BJT's Avatar
BJT BJT is offline
AKA: Ben Thorsgard
and I guess it actually says 095 right on the sticker.
Unread 04-02-2011, 17:26
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
is the only difference between the 90 and 95 the mounting tabs?
Unread 04-02-2011, 21:54
BJT's Avatar
BJT BJT is offline
AKA: Ben Thorsgard
I think so, it looks like all the specs are the same.
Unread 04-02-2011, 22:04
klmx30302's Avatar
AKA: Kevin McCarthy
oops yeah it is a 095c, but i thought we ordered the other one. And apparently the only difference is the mounting tabs. I will have more pics tomorrow (we got it mounted to our e-board today). We also are using a 80mm pc fan to cool it because it gets hot fast and really holds the heat.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Unread 05-02-2011, 02:09
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Not on your robot, you aren't. (Unless the fan is attached to a computer....) The 40 mm and 120 mm fans provided in the KOP are allowed.
Unread 05-02-2011, 07:18
klmx30302's Avatar
AKA: Kevin McCarthy
Well i guess we'll be switching that to a 120mm then...
We kept having an argument over using the 120 or the 40, so I brought in a 2pin 80mm fan as a happy medium but if we cant use it then we'll probably switch to the 120.
Our team motto...
Unread 06-02-2011, 00:57
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
No need to put a fan on the compressor for competition use it is designed to take the heat. It's native environment is under a vehicle hood which can reach an "ambient" temp of ~200 degrees and it's 9% duty cycle and max run time of 3 minutes was developed for long term longevity (many years) operating in that environment. Of much bigger concern is the fact that you removed the factory installed check valve. You need to remove your manifold and install it after the check valve. That will allow it to release some of it's head pressure internally to reduce the start up load. Running it w/o the check valve voids it's warranty.
Unread 18-02-2011, 22:00
jman22890's Avatar
jman22890 jman22890 is offline
AKA: Jordan Hostick
jman22890 is an unknown quantity at this point
Wow, huge size difference from the other one. How does this years compressor work compared to last years
