Go to Post It's always better to figure out why a design actually works and the best ways to implement it than to just assume upgrading to a "better" material will make everything work. - Cory [more]
Unread 04-02-2011, 23:09
CRLS97 CRLS97 is offline
FRC #0097
CRLS97 is an unknown quantity at this point
Using an Encoder to Measure Forklift Height
Hi,
This is Team 97 and we're all new programmers:
We have an idea to use an encoder on a motor which lifts and brings down a forklift. Is it possible to use an encoder to measure how many rotations the motor shaft makes and then of course subtract the measurement when the shaft moves in the opposite direction (thus bringing the lift down)...?
The purpose is to get a forklift height reading on the driver station.
Could anyone provide us any leads? We're using labview and we're a bit lost on how to get started. Our build team will have the encoder's on the motor shaft in a day or two.
Any leads appreciated,
thanks!
Unread 05-02-2011, 01:22
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Using an Encoder to Measure Forklift Height
In begin.vi:
1) Digital input Open
2) DevRef to "Counter to digital Source"
3) DevRef to encoder open
4) Repeat 1 - 3 for second input of encoder
5) DevRef to encoder set RefNum
In teleop.vi:
6) Encoder get RefNum
7) DevRef to Encoder Get
The encoder get can return a ton of very useful things. If you set the encoder open.vi correctly, you could get the get function to return the direct height of the arm! You can also get the direction, if it's stopped, etc.
Unread 05-02-2011, 09:44
Have you looked at the encoder examples?
The examples are great for testing out the electrical connections before you put your code into the mix. They are also good for learning to copy/paste or base your code on how an example does it. This is really useful for gaining understanding of how the sample code works, and how to modify it.
Greg McKaskle
Unread 06-02-2011, 13:34
FRC #0097
Smile Re: Using an Encoder to Measure Forklift Height
Originally Posted by WizenedEE View Post
In begin.vi:
In teleop.vi:
Thanks! Just to clarify: in begin I should initialize one encoder but have two inputs for the dio using two seperate initializers but wire them into one to have in memory and in teleop I will access them and then have them get values.
However I'm confused by where the results of the get values would appear. Will they show somewhere in the DS? (I haven't been able to experiment yet, and won't be able to until tomorrow).
Once again, thanks!
and @Greg: thanks! I'll definitely take a look at that before experimenting ^^ tomorrow!
