Re: Minibot Question
There is no rule that prevents soldering the motor wiring for any motor. In most cases it is the recommended way of attachment for motors that are not supplied with wires. That being said, soldering to motors carries some risk. The Tetrix motor terminals for example, are surrounded with plastic. Too much heat may allow the terminal to heat the plastic and short the terminal to the metal case.
