Go to Post We need to train teams from the very beginning to become self-sustaining... so we can offer a full experience to FIRST students... - Bob Steele [more]
Unread 05-02-2011, 10:56
JohnFogarty's Avatar
AKA: @doctorfogarty
Line Following Sensor Wiring.
how do you adapt the line following sensor to the digital sidecar's DIO. And what kind of feed back numbers do you get from the gray tape?.
John Fogarty
Unread 05-02-2011, 16:47
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Line Following Sensor Wiring.
Blue goes to ground and brown goes to + in PD board to a 20 amp circut breaker
Then put the white wire the digital side car as a Digital I/O
Then you use the DigitalInput.get() method
true=detected object
false=no detected object
Unread 05-02-2011, 16:54
pottsrulz3461 pottsrulz3461 is offline
FRC #3461
pottsrulz3461 is an unknown quantity at this point
This solves alot of problems for us too thanks!
Unread 08-02-2011, 13:48
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Hi there,
Just a note for you, the power for the AB photo sensors that we were given this year may also be powered by the solonoid output module on the cRio. This is so they have a nice constant power source.
The input voltage for the sensors is spec'ed at 10.8 to 30 and sometimes the voltage on the PD block can drop below 10.8VDC.
If you connect it to the solonoid module it will have a nice constant 24 volts.
Just make sure that the software turns on the port you wire it to or it won't have any power at all.
This was in update #5 I think.
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 08-02-2011, 20:02
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Also don't forget about the adjustment knobs on the sensors themselves. Turning them is the only way to adjust sensitivity, which you'll probably have to do at competition if you don't have actual field carpet and tape. The carpet this year is gray, and the lines are light gray- not much margin for error.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
