Go to Post It's a bit sad, really, because FIRST has already reached other countries and there are some U.S. states that still are unaware of what FIRST is!! - tribotec_ca88 [more]
Unread 05-02-2011, 11:56
Re: Sending Processed Image Stream to Dashboard?
While it is possible to compress and send images from the cRIO to the dashboard, it should be far less intensive to process the rectangles a bit further and send the results to the dashboard. If you like, you can then annotate the original image as was done in 2009 and 2010.
Where are you trying to put the vision assistant code?
Greg McKaskle
