Go to Post Certainly more interesting to watch than driving around in circles on a flat field. Sorry, 2008. - synth3tk [more]
Unread 01-29-2011, 03:30 PM
colinchocolate colinchocolate is offline
Java Programmer
AKA: Colin Hood
FRC #1559 (Devil Tech)
colinchocolate is an unknown quantity at this point
Our C++ is not running out of debug
Whenever I try downloading the code from winriver, it only allows us to download through debug. Whenever I go through the deploy option, it gives me the no code in robot error on the driver's station. Any ideas?
Unread 01-29-2011, 03:37 PM
Austinh100's Avatar
Austinh100 Austinh100 is offline
FRC #3695 (Foximus-Prime)
Austinh100 is an unknown quantity at this point
Re: Our C++ is not running out of debug
We are having the exact same problem, any help would be appreciated
Unread 01-30-2011, 06:42 AM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Hook up the debug console to see what failed. We had a similar problem last year and found out our code was exceeding the 16-bit "call" distance so we had to add -mlongcall in the linker option to get the code to load.
Unread 02-01-2011, 08:16 PM
Java Programmer
AKA: Colin Hood
-mlongcall worked great! Thanks!
Unread 02-01-2011, 10:16 PM
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Pro tip: In Window->Preferences you can set default build properties so you never have to worry about these things
Unread 02-05-2011, 11:53 AM
Java Programmer
AKA: Colin Hood
Hooray! Another error. we are getting a "Relocation value does not fit in 24 bits" message. I added the -mlongcall tag in the build properties>build command. Anyone have any ideas? It worked before after we added the tag, but stopped working suddenly this weekend.
Unread 02-05-2011, 11:56 AM
HutchScout HutchScout is offline
Programming Mentor
AKA: Steve Hutchinson
FRC #0617 (The Enginerds)
HutchScout is an unknown quantity at this point
We are also getting the same "Relocation value does not fit in 24 bits" message on our NetConsole when the bot attempts to load FRC_UserProgram at startup. Trying to find a solution.
Don't panic ... it's only ones and zeroes
