Go to Post "Don't you wish your drill bit was hot like mine?" - BariSaxGuy [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 03-02-2011, 15:55
Shantali Shantali is offline
FRC #3609
Shantali is an unknown quantity at this point
Re: Single Joystick Tank Drive
It does say 0.0 at the beginning, but after driving it for a bit then letting go, it doesn't always center perfectly.
Both of our joysticks do that :\
Unread 03-02-2011, 16:00
Clean the Mountain Dew out of them.
Unread 03-02-2011, 17:19
FRC #3609
They're clean outta the box ones... :'(
Unread 03-02-2011, 17:30
Maybe there's an error in your software?
Try loading the default code that came with the LabVIEW installation and run it and see if it does the same thing.
Unread 05-02-2011, 02:28
FRC #3609
After updating and running stuff again, joysticks center within 0.05 from center. Still not a perfect 0.
However, after playing around with various types of if statements, I'm starting to get the impression that the default way is the only way of making it operate smoothly.
If you look at the http://web.goodrobot.com/blog/wp-con.../tankdrive.png diagram clockwise, by default we get the "motor forward x3, motor off, motor backward x3, motor off" pattern.. That way there is never a situation where the motor has to abruptly switch directions.
If swapping the reverse directions, we get "motor forward x3, motor backward x3, motor off, motor backward, motor off". That way at some point there's an abrupt change in motors from going backwards to forward. That is the issue I've been having and at this point I see no way of avoiding it.
If I'm wrong, please correct me.
Unread 05-02-2011, 12:55
I think you are correct.
I believe the pseudo-code below implements the behavior shown in the diagram you referenced:
float Xj, Yj, L, R;
float max, sum, dif;
max = abs(Xj); if (abs(Yj)>max) max = abs(Yj);
sum = Xj+Yj; dif = Xj-Yj;
if(Yj<=0)
 if(Xj>=0)
  // first quadrant
  L =  max;
  R = -sum;
 else
  // second quadrant
  L =  dif;
  R =  max;
else
 if(Xj>=0)
  // fourth quadrant
  L =  dif;
  R = -max;
 else
  // third quadrant
  L = -max;
  R = -sum;
If you want to reverse the direction of rotation when backing up, I believe the following modified code would do that (note the addition of some deadband to address your concern about abrupt motor direction changes*):
float Xj, Yj, L, R;
float max, sum, dif, deadband;
if (Yj>-deadband)&&(Yj<deadband) Yj=0;
if(Yj<=0)
 if(Xj>=0)
  // first quadrant
  L =  max;
  R = -sum;
 else
  // second quadrant
  L =  dif;
  R =  max;
else
 if(Xj>=0)
  // fourth quadrant
  L = -max;
  R =  dif;
 else
  // third quadrant
  L =  -sum;
  R =  -max;
*if using Jaguars, you may want to experiment with putting the jumper in the "coast" setting to avoid abrupt motor braking when transitioning into/out_of the deadband zone
Last edited by Ether : 05-02-2011 at 14:54. Reason: added footnote; corrected modified code
Unread 05-02-2011, 18:09
FRC #3609
I've tried having a dead zone, treating everything within 0.1 from the axis, as 0.
Then problem is that when you move the joystick all the way right to turn on the spot, then move it slightly forward, then slightly backwards, you can hear the motors clicking as they're going from "left forward right backwards" to "left backwards right forward".
I tried to play around with giving it more of a dead zone when turning on the spot
//x, y = joystick position
if (abs(x) > 0.5){
   if (abs(y) < 0.3)
      y = 0;}
to fix that, but it didn't work that well either.
I think my driver will have to get used to driving the way it was originally, with swapped reverses.
Unread 06-02-2011, 09:11
Have you considered doing something a little more advanced?
You could install the gyro and use it so that the driver interface would allow the driver to issue field-centric commands. The driver points the joystick, and the vehicle turns and goes in that direction at a speed determined by the magnitude of the joystick displacement.
Unread 07-02-2011, 19:58
FRC #3609
I love the concept, but it's a little bit more advanced than I can manage at the moment :\ This is our rookie year, and there's a lot more to figure out. Maybe in the future!
Thanks so much for your help
Unread 23-03-2011, 15:40
maleche maleche is offline
Senior Engineering Program Manager
maleche is an unknown quantity at this point
This is a great subject. I am working on the same concept using Visual Basic. I have a scaled Picture box with -128,128, 128,128 set as the scaled box points. Center is 0 (zero) with adjustable deadbands in both X & Y centered.
Moving a joystick OR mouse sends the Xj, Yj or Xm, Ym directly to the motor controller, after calculations.
I am using pythagorean for vector speed (Vel) based on joystick/mouse angle and distance from center. This works great in direct Y and -Y vectors ( both treads move at same speed and direction). -X, X will rotate Left and Right tank treads in opposite directions at equal speed. When steering slightly left and forward (Xj=-20, Yj=50) the total vector is the Sin(Angle)* Vel. This does well when transitioning from full forward to left/right steering. I'm still working out some bugs. I have not considered Tan2 yet or using a Gyro to steer by. The motor controller is a Sabertooth 2x50 and using 0-127 as speed with direction tokens.
One thing to consider however, is when going from full forward to all-stop. This can tip the robot or cause problems with stability. I programmed a ramp-down speed Vel=Vel-ramp^2. this allow VERY smooth and quick stopping transitions.
Keep in touch!
Doyle
Unread 23-03-2011, 18:31
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
As for the gyro-guided driving, I know that labview has a rotate axis vi built in. Not sure if java has it or not but the challenge is finding a way to get it to turn completely because as it comes closer to the direction your pointing the joystick the less exaggerated the turn becomes because you are moving closer to 0 on the x-axis and if your turning too fast then your gyro loses its accuracy. Good luck
