Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
Unread 05-02-2011, 15:38
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
2011 Camera Code on Driver Station
So I have been working on camera code all day. Currently I am able to track targets based off of color and determine weather or not they are in a line.
Currently the most limiting factor is network speed which is keeping the FPS to about 15.
So if I were to release this to you guys how would you want the data returned to the cRio?
Example of ways data could be returned
1) Raw centroids and sizes
2) Pole positions (calculated based off the difference in x position)
3) Raw frame difference
4)??
I plan on (once it works well enough) releasing the application and the source code.
General rules on the usage of the source:
1) You may modify and redistribute at will.
2) You should be nice and credit me for the use
3) If you make improvements that helps tracking send the modifications to me so other teams can use it as well (Remember Gracious Professionalism)
Unread 05-02-2011, 15:50
AKA: Bryant
Re: 2011 Camera Code on Driver Station
PS here is a low-res teaser of what I have at the moment
Unread 05-02-2011, 16:43
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
What language would this be in?
Unread 05-02-2011, 17:05
AKA: Bryant
The core is java over processing which would be able to send data to the cRIO via udp
Unread 05-02-2011, 17:13
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I plan on using reflection from infrared if possible, if not LED off of the reflection tape on the scoring peg. The Camera will detect this. I have set the camera to grey-scale since full color is unnecessary and take up more space. Maybe use the reflection detected to also detect a circle with some help from the occlusion feature. This can further be used possibly to calculate distance from that circle or help align the robot to the column.
Unread 05-02-2011, 17:46
AKA: Bryant
This software runs on the driver station with the camera plugged into the netgear router. The program does all of the calculations to determine where the reflective tape is and then subtracts the background (the green and red area) then the frame is run through openCV to detect the blobs and do those calculations. Finally the blobs are compared to each other to determine which ones are in a column. Other calculations coming would be angle and distance to targets.
The software then returns the target information (not the image) to the cRio where you would then do your own processing.
Unread 06-02-2011, 10:45
The latest LabVIEW update also contains an example under the vision category that shows how to statistically locate the columns. It runs on the development computer and uses a folder of images as inputs, so even if you are going to code in Java or C++, you can use it to tune colors, adjust lighting, etc.
Post any questions you have about how it operates.
Greg McKaskle
Unread 07-02-2011, 22:34
AKA: Bryant
I will be releasing the alpha before mid-day tomorrow. Keep your eyes pealed.
Unread 08-02-2011, 10:14
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
also note that the tape on the circle peg is not actually circular,
on the kickoff field it was square. So personally I would not plan on using the circle in your processing, because it very well may not be a circle at competition
Unread 09-02-2011, 00:24
divixsoft's Avatar
divixsoft divixsoft is offline
FRC #0835
divixsoft is an unknown quantity at this point
Could you make the output the pole positions? Also, I admire your effort, the camera code is incredibly complex and hard. When and where will you post this code?
Unread 09-02-2011, 12:32
AKA: Bryant
Ok everyone.
The alpha can be found on my site at http://www.satanicspider.com/frc.php
You will need to do the following to get it running
I have not tested the networking end very much (lack of time) if you run into problems let me know
**IMPORTANT**
Do this in this order or it wont be installed properly
1 Install openCV version 1.0 (not 1.1 pre)
2 Install openCV version 2.1
3 Make sure that .\lib\ is added to the PATH system environment variable
**For people running vista or 7**
4 copy all of the DLL files from the bin directories of BOTH openCV directories into the lib subfolder in the Axis Tracking folder.
Known issues:The pole tracking isn't finished yet but it works as it is. As you approach the poles the upper points will converge towards the middle of the image. I did not compensate for that but it is on my list of things to do.
Let me know if you have issues.
Unread 09-02-2011, 12:36
AKA: Bryant
I will consider that for the next release. At the moment it reports each point in each pole (x, y, size) the poles are divided by 2 bytes with a value of 255
Unread 09-02-2011, 12:57
divixsoft's Avatar
FRC #0835
Where is the source code?
Unread 09-02-2011, 12:59
AKA: Bryant
Good observation. It will be available in the same place after I clean it up a bit ^_^
[EDIT]
Its up
Unread 09-02-2011, 13:53
divixsoft's Avatar
FRC #0835
what do you guys think of this code? and how do you transfer the processing from the crio to the classmate using the classes from frc?
