Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Unread 05-02-2011, 17:33
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Attack 3 Joystick
I'm using labview to program our robot and want to setup the joystick. I know how to set certain buttons to do things, but how i make it so when the actual joystick in the middle is pushed forward, the robot moves forward. When the joystick is pushed to the right or left, it goes that way, and reverse when pushed back. Are their button numbers assigned to this that i just don't see? What do i need to do?
Thanks
Unread 05-02-2011, 17:41
Re: Attack 3 Joystick
That's called Arcade Drive.
The default code is setup to do this with 2 motors.
Unread 05-02-2011, 17:50
FRC #4272
it should still work with 4 motors correct?
Unread 05-02-2011, 18:00
Yes, it should still work.
If you guys meet in the evening Monday or Tuesday, I can come out and help you run through your questions.
Unread 06-02-2011, 00:00
FRC #4272
Thanks. About coming to our school, that's something i would ask Mr. Monte about. If you need his email, let me know.
Unread 06-02-2011, 09:42
Mr. Monte is sending out an email to see when all of you can meet after school.
Unread 07-02-2011, 06:31
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
AndrewD is an unknown quantity at this point
you'll want to set up four motors in begin vi and use the axis 1 (y) and axis 2 (x) and make your own arcade drive.
____________________________________________
FRC Team #1243 - The Dragons
Unread 07-02-2011, 09:49
Why make their own? Do you think there is something about the built-in arcade drive that makes it unsuitable for a team trying to get their robot to move under joystick control?
