Re: d-link bridge
Sounds normal.
When you change the DLink IP address, your PC will no longer be able to communicate with it. So the Saving settings page will never return,because it's trying to load the old IP address that doesn't exist anymore. In addition, they wouldn't be able to communicate even at the new DLink IP address, because suddenly your PC and the DLink are on two different incompatible networks. After you click save settings that change the DLink IP address you need to go change your PC IP address to 10.xx.yy.5 again. Then browse to the DLink's new IP address at 10.xx.yy.1 Last edited by Mark McLeod : 05-02-2011 at 23:29. |
Re: d-link bridge
thanks
Re: d-link bridge
Is it necessary to go back there to change things? Or is it just in case you want to mess around with stuff. |
Re: d-link bridge
You just have to pick an IP that is not used by another device. A high number practically guarentees there will be no IP conflicts since cRIO uses .2, DriverStation default to .5 etc.
Re: d-link bridge
Anything .6 and above is free and clear. Quote:
There is often some fiddling with straightening out the IP addresses on the Classmate to switch the Driver Station application between the wireless and wired networks. You have to make sure the wired network adaptor IP address is different than the wireless IP address. Only one of them can be .5 And you have to make sure the Driver Station app. doesn't keep trying to use the old one. |
Re: d-link bridge
Re: d-link bridge
Our Driver Station likes to set itself to .9 when on the robot wireless network.
#8
Re: d-link bridge
I wonder how it decides to do this? Maybe if .5 is already taken? Have to experiment if Greg McKaskle doesn't tell us. That could cause unusual problems for teams using laptops as competition Driver Stations. Something to watch out for on practice day. |
#9
Re: d-link bridge
If the DS is managing the NIC, it will add .5 to the LAN NIC and .9 to the wifi NIC. If you plug into the field, the laptop should use the wired route, but if it were me, I'd turn off wireless anyway.
Greg McKaskle |
