Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 05-02-2011, 01:51
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Line sensor spacing
How far apart do the three line sensors need to be spaced? Also, which two wires, and which direction are they supposed to be plugged into the digital I/O of the digital sidecar?
Unread 05-02-2011, 09:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Line sensor spacing
I'm not sure about the spacing, but I know there's a knob to zoom in and out. I plan on using 1.5" spacing for now.
The brown wire is your plus, the blue wire is your minus. Those go into the power panel. A pull-up (6.4K if i'm remembering correctly) resistor bridges the power and signal ports on the digital side car and the white wire connects to the signal port as well. (See attached) The black wire can be covered up with a piece of electrical tape, so It doesn't blow the whole sensor if it touches something accidentally. Since I'm doing this all from memory, I'm not liable if you blow something.
Unread 05-02-2011, 10:40
AKA: Ty
Is that resistor something that you found and put on, or is it already there, or did it come in the KoP? Where did it come from?
Unread 05-02-2011, 13:08
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Check out this thread for wiring. http://www.chiefdelphi.com/forums/sh...threadid=88548
It sounds like because of how the Digital Side car is engineered it should not need a resistor. - Don't quote me on this.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 05-02-2011, 13:32
Peyton's Avatar
Peyton Peyton is offline
Electrical Captain 1591
FRC #1591 (Greece Gladiators)
Team Role: Electrical
Peyton is an unknown quantity at this point
The control board has a resistor in it already.
Unread 05-02-2011, 19:20
cgmv123's Avatar
AKA: Max Vrany
implosionprez, we had the resistor lying around. They're cheap and you can get them at any hardware store.
Peyton, it didn't work without the resistor and it did with it. Read that however you want.
Unread 05-02-2011, 19:26
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
It should have worked without the resistor, the sidecar has a pull-up resistor built in to it. I would double check all of your sensor connections as well as your digital sidecar connections, perhaps you don't have the power connections correct and your internal pull-up isn't receiving power. If you'd like to contact me directly I can try to direct you further.
Under normal circumstances, you can connect the dark output (DO) or light output (LO) of the light sensor directly to your input on the sidecar.
Matt
Matt Krass
Unread 05-02-2011, 19:46
theschell theschell is offline
FRC #0768
theschell is an unknown quantity at this point
1.5" is to close. we found this out by programming them.
Unread 05-02-2011, 19:50
cgmv123's Avatar
AKA: Max Vrany
theschell, we actually ended up going even closer. There's a zoom knob you can use to adjust the depth of field.
Unread 05-02-2011, 20:39
FRC #0768
cgmv123, we are trying to get our followers to follow our line. So far we follow and our teleop mode doesn't switch. We dont know what is wrong.
Unread 05-02-2011, 21:09
cgmv123's Avatar
AKA: Max Vrany
If you're following OK, that's not something with the sensors then.
Unread 06-02-2011, 15:55
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We spaced ours far enough apart so that if the center one sees the line (yellow light), then the outsides ones dont. I think they were an inch and a half apart. Probably depends on the height. We can't get into the school on Sunday to work.
Brian K
Team 1225 Robotics Mentor
