Go to Post Hyper, I want to marry your robot. - Keys [more]
Unread 05-02-2011, 16:05
BFKelleher BFKelleher is offline
AKA: Brian Kelleher
FRC #0620 (Warbots)
BFKelleher is an unknown quantity at this point
Update Problem - Windows 7 Can't find setup.exe
One of our main programming laptops is having trouble updating LabVIEW. We've downloaded it a few times and used a downloaded copy that worked on a different computer, but we keep running into this problem:
Running autorun.exe makes nothing happen after we tell to program install the update.
Running setup.exe returns this error:
The filepath is irrelevant. This error occurs no matter where the file is.
Oh, and by the way, we are running Windows 7. If that helps.
Unread 05-02-2011, 21:27
Re: Update Problem - Windows 7 Can't find setup.exe
Check to make sure your antivirus program is turned off before trying to run the update.
