Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 05-02-2011, 15:10
fishLlama fishLlama is offline
Caffeine Addict
FRC #3018 (Team Rocket)
fishLlama is an unknown quantity at this point
FRC Java cRIO 2011 update broke things.
Whenever we deploy code, we get past the bootup sequence but then it gives this error and halts:
[Squawk VM] Version: 2011 FRC, Feb 2 2011, 13:26:47
[cRIO] Uncaught exception in Thread.run():
[cRIO] on thread com.sun.squawk.imp.MIDletMainWrapper - main
[cRIO] java.lang.IllegalArgumentException: MIDlet-1 property must exist in META-INF/MANIFEST.MF
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(74)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO]
[cRIO]
[cRIO] --------------------------------------------------------------------
[cRIO] GCs: 1 full, 0 partial
[cRIO] ** VM stopped: exit code = 1 **
[cRIO] task 0x21d1dc0 (SquawkRobotTask) deleted: errno=0 (0) status=1 (0x1)
Soo... anyone else have this problem? Have any idea how to fix it?
Unread 05-02-2011, 15:25
Ben_R_R's Avatar
Ben_R_R Ben_R_R is offline
Assistant Programing Mentor
FRC #2194 (Fondy Fire)
Ben_R_R is an unknown quantity at this point
Re: FRC Java cRIO 2011 update broke things.
In NetBeans, under the files tab, navigate to "resources\META-INF" and open the file called "MANIFEST.MF", you should see something like this:
MIDlet-Name: Dev Robot Code (2-5-11)
MIDlet-Version: 1.0.0
MIDlet-Vendor: FIRST
MIDlet-1: RobotMain, , edu.wpi.first.wpilibj.templates.RobotMain
MicroEdition-Profile: IMP-1.0
MicroEdition-Configuration: CLDC-1.1
Can you verify that the line that starts "MIDlet-1" is present? If it is, make sure it lists the right class and package. If it is not there, add it, putting the name of your main robot class and package as shown above.
Hope that helps!
2194 Alumni and Mentor
Unread 05-02-2011, 21:38
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
We don't have this problem, but the cRIO is definitely not connecting with the laptop. They are connected via Ethernet, the ip does respond when pinged, but when we try loading code, we got this lovely feed
Waiting for cRIO to reboot (1s)
Waiting for cRIO to reboot (2s)
Waiting for cRIO to reboot (3s)
Waiting for cRIO to reboot (4s)
Waiting for cRIO to reboot (5s)
Waiting for cRIO to reboot (6s)
Waiting for cRIO to reboot (7s)
Waiting for cRIO to reboot (8s)
Waiting for cRIO to reboot (9s)
Waiting for cRIO to reboot (10s)
which continued until we stopped it at (56s) because the code clearly wasn't deploying. Help (please)?
Unread 05-02-2011, 22:17
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
@1168Programmer You loaded the code over ftp, if you try driving it, it's probably running the new code. Make sure you're mask is 255.0.0.0 on the programming laptop, that can cause your issue.
Unread 05-02-2011, 23:03
Head Programmer/CEO
FRC #1168
Team Role: Student
ok, will have to give that a try. Thanks.
Unread 05-02-2011, 23:17
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Unhappy Re: FRC Java cRIO 2011 update broke things.
we cant get update #8 (re imaging the cRIO) to work
any one know where i can get it at
Unread 07-02-2011, 14:38
Ben_R_R's Avatar
We had to manually move the update (located in the folder: sunspotfrcsdk\cRIO_Images ) to the folder the labVIEW imaging tool uses to store the images. I don't have the path to that on though, perhaps someone with labVIEW experience might be able to help you if you can't find it.
Unread 07-02-2011, 20:39
WPILib Developer
FRC #0348
The update should automatically be placed in $HOME_DIRECTORY/sunspotfrcsdk/cRIO_Images . At least Netbeans automatically does it for me. (Eclipse doesn't).
Here is version 27: http://dl.dropbox.com/u/3131221/FRC_2011_v27.zip
Although if you don't have it lying around somewhere on your computer, you probably haven't upgraded.
