Go to Post I told people that I was a summit for world leaders for our regional. We had two that are current world leaders and over 1000 that will be ones in 2029. - Foster [more]
  #31   Spotlight this post!
Unread 27-01-2011, 21:44
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: usage of denso window motor
If your still interested check out this photo gallery. We cut two plates using aluminum, and then got spacers to put in between them We drilled holes in the black plastic thing, and bolted a gear to that. We then put the top plate on holding the plastic thing in place.
http://forums.trossenrobotics.com/ga...age.php?i=3734
I included an STP file as an attachment.
Edoga
2980
  #32   Spotlight this post!
Unread 03-02-2011, 07:21
Steve Compton Steve Compton is offline
Project Manager, Mentor
FRC #1391
Steve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to behold
Hey Arthur, Nice work! Do you have any kind of CAD file you could share?
Originally Posted by artdutra04 View Post
If you have access to CNC machines (through your shop or via sponsors), you can machine your own sprockets. The Denso motors also do not like cantilevered loads, so you should always support the shaft with another bearing/bushing. Here's some 7075 aluminum sprockets with a Denso hub pattern that I machined last year for 228.
The Denso motor, sprocket, and shaft support (with Delrin bushing).
  #33   Spotlight this post!
Unread 03-02-2011, 07:23
FRC #1391
opps - there it is, thanks!
Attached is a STEP file of the sprocket I machined in the photos above. All I did was download a regular sprocket model from McMaster-Carr (they have CAD models for most of their hardware (screws, nuts, shoulder bolts, sprockets, etc) on their website), use calipers to measure the metric output "spline" of the Denso motor, draw it on the part, and extrude cut it.
To machine it was a four step process. The first thing I had to do was machine a fixture plate out of 6061 aluminum. Then I machined about 90% of the sprocket features onto the 1/2" 7075 aluminum raw material. Then I took that part out, bolted it to the fixture plate upside down, and machined the sprocket teeth into it. The last step is to use a lathe or hand file to bevel the teeth.
There is nothing in this CAD model to keep the sprocket on the shaft of the motor or to support it for cantilevered loads. In the second photo I previously posted, our solution was to machine a custom bushing out of Delrin to both support the shaft and to keep the sprocket laterally in place on the shaft.
  #34   Spotlight this post!
Unread 05-02-2011, 23:06
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Originally Posted by ttldomination View Post
What my team has done is taken the cone shaped outside part of the coupler and ground away some of the material. This allows a 1.125" sprocket to slide in there nice and snug. Screw in the sprocket and you're set.
Also, the output shaft is a 8mm key shaft. You can purchase this shaft from AM or another provider and use the 8mm key AM hub found here, and attach a sprocket to that.
Hope that helps,
Sunny
Is there a link to the 8mm key shaft on AM? I can't seem to find it
  #35   Spotlight this post!
Unread 05-02-2011, 23:12
ttldomination's Avatar
Sunny
Actually, the shaft is a 8mm radius. We've found success using a .625" shaft.
- Sunny
1648: 2013-2014
5283: 2015
  #36   Spotlight this post!
Unread 05-02-2011, 23:14
AKA: Brandon Liatys
- Sunny
Guessing this isn't on AM or some other website, already with a key slot in it?
  #37   Spotlight this post!
Unread 05-02-2011, 23:29
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
We are getting custom sprockets much like Arthur's machined. I don't know if it will help anyone, but here is our base technical diagram.
Name:	sprocket diagram 1.jpg
  #38   Spotlight this post!
Unread 23-02-2011, 16:57
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Is These chain #25 Or #35 series
the next quation do you have base technical diagram
TEAM 1946-Tamra
  #39   Spotlight this post!
Unread 23-02-2011, 18:07
clayman's Avatar
AKA: Clayton
It's for #35 chain, and the diagram is already attached on my previous post.
  #40   Spotlight this post!
Unread 24-02-2011, 08:15
yara92's Avatar
AKA: Mohamed
Yes, I meant the sheet metal
TEAM 1946-Tamra
  #41   Spotlight this post!
Unread 24-02-2011, 10:52
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
In the past my team has made stepper shafts that are right OD for the KOP window motor adapter and then are turned down on a lathe to .5, then we ether had one of our sponsors key the shaft or we did it on a bridgeport at our shop.
it has worked well for us in the past. but you do want to support the other end of your shaft and the KOP adapters have broken on us before so spares were always good to have.
  #42   Spotlight this post!
Unread 22-03-2011, 12:05
CordovaRover CordovaRover is offline
FRC #3327
CordovaRover is an unknown quantity at this point
Lightbulb Re: usage of denso window motor
We used this motor this weekend at the peachtree regional and had no success with it. Needless to say we didn't use a sprock. One of our sponors is willing to machine the sprocket for this part if we had it in a CAD file. Can you share the file you have with use so that we may have this part made for our next regional in Knoxville?
  #43   Spotlight this post!
Unread 22-03-2011, 12:06
FRC #3327
  #44   Spotlight this post!
Unread 22-03-2011, 14:55
clayman's Avatar
AKA: Clayton
Read the entire thread
http://www.chiefdelphi.com/forums/sh...4&postcount=25
