Go to Post instead of complaining, suck it up, think a little harder, and make the most of what you do have. - Andy Grady [more]
Unread 03-11-2002, 20:56
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Question Good with Audio Wiring? Help me please.
I've seen a couple teams use boxes with speakers and cd players in them. I've also seen cart audio done. My real question is: How do i get my portable cd player to play through some car speakers(that aren't in my car).
What power supply?
How hard is it to do?
What supplies needed?
Thanks in advance.
Like Aquidneck Island Robotics on Facebook!
Unread 03-11-2002, 21:01
MacZealot MacZealot is offline
MacZealot is an unknown quantity at this point
Send a message via AIM to MacZealot
Ok, I haven't done this before, but I can give you a bit of insight.
First of all, you will need an amplifier. Typically, to my knowledge, 'receivers' actually do act as amplifiers, so you will be fine there. JUST MAKE SURE THE OHM rating matches!
As I said though, a receiver depends. Now seeing that you want to stick this into a cart, (bot?), you will want to use a DC amplifier, be very careful with your choice.
To my knowledge, you might also need a console of sorts, not sure what to go about there, but good luck.
AIM: Joe7464685192 | Email Me! Visit my site!
Uh I'm STILL not in Las vegas GRRRR!! I dun think it'll happen till june and This shoulda happened a freaking year ago
Unread 03-11-2002, 21:05
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
WhitePaper
This sounds like something that could be turned into a pretty good "white paper". Most teams probably know how to do this kind of stuff or know someone who can, but it would always be good to have this documented (even though each setup/speakers/player would be different)
Just an idea.\\
Purdue Alumni
Cummins, Inc.
Unread 03-11-2002, 21:13
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
If you get a decent pair of powered speakers, you can just plug them straight into your CD player and it should work just fine. You may need an adapter depending on the plugs on each end, but that shouldn't be more than a buck or two.
Unread 03-11-2002, 21:42
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, pick up some PC Speakers or something. A portable CD Player probably won't be able to drive car speakers very well. If you had a car radio that you could probably pick up from a junkyard or something you could get decent sound out of car speakers. Make sure the impedance on the speakers meets or exceedes the mininimum on the amp too
Unread 03-11-2002, 21:46
NOW THAT I THINK OF IT...
You could probably get a small low-power set of computer speakers and rip the power adapter off, then use capacitors and plug it into the battery
Unread 04-11-2002, 01:28
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Car speakers aren't powered speakers.
All you need is an amplifier and a power source to play your discman on your car speakers. You can actually play to the speakers directly, but an amplifier will make it audible.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 04-11-2002, 09:27
Matt Reiland's Avatar
'The' drive behind the drive
Cool Seriously Though
If you want to make the sound louder than that of a computer with the little 5 watt computer speakers you are going to go to a car system like many of the teams have. Most portable CD players will have a line out jack or an adapter to take the headphones to a variable line out with RCA's. You most definately will have a 12 power source similar to the robots or as big as a car battery. Next will come a 12v car audio amplifier with something in the range of at least 30W probably just a 2 channel, finally the speakers, automotive 4 ohms will work the amplifier better than home 8 ohm speakers. The amplifier and speakers can be found at most stores but better yet go to ebay and buy it on the cheap. Hook it all up, use the CD player for the volume or the amp might have a line level adjustment. A good speaker size would be 6x9, they have OK base for their size but if you want more get at least an 8" sub also (10-12 prefereable)
Unread 04-11-2002, 17:43
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Also you could just buy a face plate for a car stereo, then get a few 3 way speakers anda battery to power it all from. Faceplates have built in amplifiers, i know sony ones get up to 50 watts for 4 channels, that could be enough. A good thing to do would be find a car audio place in your town and talk to them. Usually they are very helpful, specially if you make it seem you are going to buy stuff from them. Maybe they would be willing to help you out and you can make a sweet system for the cart, not just some wimpy system. But if not im sure there are tons of things on the net to help you out.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 04-11-2002, 21:17
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Go rip the speakers and HU out of a Chevy. Those things have nice OEM stereos. Then just get a tape adapter for your cd player. All you would need to rig up is the power supply. That would most likely be the easiest and cheapest way to get the job done. If you want something to annoy the DJ playing the loud music at the regionals, expect to pay like $300+ (For that, I would get Kenwood 3-ways and a 12" sub along with a Pioneer HU and a Blaupunkt amp)
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 04-11-2002, 21:41
dixonij's Avatar
dixonij dixonij is offline
I feel like Rip VanWinkle
None #0087 (Rancocas Valley Robotics)
dixonij is an unknown quantity at this point
Send a message via AIM to dixonij
i know nothing about speakers but i did see a team who rigged up their prevous year's bot with a huge woofer and two 3 in. tweeters. they also put a cd faceplate on it and put neon lights in it to make it look all cool.
1 year, a broken thumb, and a hiatus from robotics im back baby!
Duct tape can fix everything execpt relationships with other people...
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
Do u thinks its a good idea to start 2004 anim? Salik Syed 3D Animation and Competition 22 31-03-2003 00:48
Check this stuff out: good websites LBK Rules Chit-Chat 3 15-01-2003 10:28
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
Good luck to all at Nats Ben Mitchell Chit-Chat 0 18-04-2002 19:59
