Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Unread 06-02-2011, 08:50
Re: [HOW TO]Remove motion blur on the camera by forcing a low exposure time
These files are on the camera. You should be able to ftp into the camera. Be very careful not to change or delete other files.
Greg McKaskle
Unread 15-02-2011, 23:21
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Question Re: [HOW TO]Remove motion blur on the camera by forcing a low exposure time
I was able to FTP to the camera. I spent a lot of time poking around, but I did not find /dynamic/image.conf
Does anybody have a more precise location for this file? We really need to turn the gain down on our camera.
Thanks,
Geoff Nunes
Unread 18-02-2011, 07:09
I've never done the file change either. If I want to shorten the exposure, I point the camera at a bright light source with it set to auto, count to five, then set to hold and point at the field. This is not a very repeatable calibration, but you can use the same principle.
If you are doing this, keep in mind that the exposure calculation is probably based on area. A single spot of bright light will likely not cause the exposure to change. A big spot of bright light probably will. If I have time, I'll look on the cameras for the file mentioned earlier and give a more precise path.
Greg McKaskle
How to remove partial lines in Ink'n'Paint rjbman 3D Animation and Competition 3 14-02-2010 01:02
Saving Camera Exposure and White Balance Holds after Restart? Mr. Lim Programming 12 29-01-2010 12:02
To Remove or not to Remove..that is now the Question? ShadowNinja General Forum 16 04-01-2009 18:29
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Low Battery Warning most of the time? archiver 2000 4 23-06-2002 23:14
