Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 07-02-2010, 18:24
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
[HOW TO]Removing motion blur on the camera by forcing a low exposure time
As anyone who has setup the AXIS Camera knows, there is no way to set the exposure time explicitly from the setup web page. I needed to force the exposure time down in order to keep tracking this years target while moving, so I looked around on the file system and figured it out.
There are three values that have an available settings of "Hold Current" that are saved between power cycles. These values are simply stored on the file system under /dynamic/image.conf (it may be slightly different, but I don't have the camera with me at the moment). It is a text file with three lines:
HOLD1=x.xxxx
HOLD2=y.yyy
HOLD3=zzz
The third line is the exposure and is a number between 0 and 1000 (I don't know if that's inclusive or not). I don't know what the number represents, but I believe it to be milliseconds (lower is a lower exposure time).
To force the exposure low:
  1. Set the exposure to Hold Current.
  2. Go to the script editor (I forget where it is right now, but it's near the same place you create backups).
  3. Find /dynamic/image.conf
  4. Set HOLD3 to the desired value (150 was a good value for me).
  5. Save the file.
  6. Power cycle the camera.
This doesn't work every time, and seems kind of random, but once it works, it will stay between power cycles. Once you get it working I recommend backing up the settings and not changing the exposure programmatically.
With this change I was able to get tracking working at 8fps even while wildly flailing the camera around .
Unread 07-02-2010, 19:55
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: [HOW TO]Remove motion blur on the camera by forcing a low exposure time
Great tip Michael!
We've been looking for a solution for this for quite some time.
Thanks for sharing!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 03-02-2011, 21:53
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Re: [HOW TO]Removing motion blur on the camera by forcing a low exposure time
Michael-
I can't find this file. Is it on my PC? On my cRIO?
If it is on my cRIO, how do I access the file system on that computer? Is there a tool for connecting to it's operating system directly?
Unread 03-02-2011, 21:59
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Originally Posted by gnunes View Post
Michael-
This was for last years camera. The new 2011 camera seems to work fine without this change.
Unread 04-02-2011, 09:31
And... we have last year's camera! If anyone can help here, this would be much appreciated.
Unread 06-02-2011, 01:16
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I got the impression that they were discussing files which reside on the camera itself. I'm not sure how to go about accessing them, it might be possible to ftp into the cameras ip address? I don't recall seeing a file explorer accessible through the web based config. page.
Unread 06-02-2011, 08:50
These files are on the camera. You should be able to ftp into the camera. Be very careful not to change or delete other files.
Greg McKaskle
Unread 15-02-2011, 23:21
Question Re: [HOW TO]Remove motion blur on the camera by forcing a low exposure time
I was able to FTP to the camera. I spent a lot of time poking around, but I did not find /dynamic/image.conf
Does anybody have a more precise location for this file? We really need to turn the gain down on our camera.
Thanks,
Geoff Nunes
Unread 18-02-2011, 07:09
I've never done the file change either. If I want to shorten the exposure, I point the camera at a bright light source with it set to auto, count to five, then set to hold and point at the field. This is not a very repeatable calibration, but you can use the same principle.
If you are doing this, keep in mind that the exposure calculation is probably based on area. A single spot of bright light will likely not cause the exposure to change. A big spot of bright light probably will. If I have time, I'll look on the cameras for the file mentioned earlier and give a more precise path.
Greg McKaskle
How to remove partial lines in Ink'n'Paint rjbman 3D Animation and Competition 3 14-02-2010 01:02
Saving Camera Exposure and White Balance Holds after Restart? Mr. Lim Programming 12 29-01-2010 12:02
To Remove or not to Remove..that is now the Question? ShadowNinja General Forum 16 04-01-2009 18:29
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Low Battery Warning most of the time? archiver 2000 4 23-06-2002 23:14
