Go to Post In 2001 instead of staring at the field at the game I turned around and watched the people watch the field. All I could see was a mass of people from all corners of the world, eyes lit up, gears turning in their heads. That, to me, is FIRST in action. - Jessica Boucher [more]
Unread 06-02-2011, 11:08
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
How to set up mutiliple programs based on field location
During last year's competitions, I was able to see that teams were able to create switches for their robot which told the robot what to do based on their location on the field. Does anyone now how this is done or any clue about it or as to where to get information about such a thing? Is it electrical wiring or programming?
For example press a switch (or flip a switch) "A" (out of three) and the robot does only the things programmed for that switch.
Unread 06-02-2011, 11:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: How to set up mutiliple programs based on field location
The typical way to do this is to read the switches (whether on the robot or the Driver Station) at the beginning of Autonomous mode, then use a Case Structure to choose which code to run based on the input.
You can see an example of this behavior in the default Autonomous code. It is setup to use 2 switches attached to the Cypress PSOC on the Driver Station in order to select between straight, left Y or right Y. In the default code the Case Structure only effects a small portion of the code, but it is often wrapped around a larger chunk of code to switch between very different autonomous modes.
Unread 12-02-2011, 12:21
FRC #3059
Thank you.
