Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
Unread 05-02-2011, 10:08
jackdawg's Avatar
jackdawg jackdawg is offline
AKA: Wyatt Cerilli
FRC #1307
jackdawg is an unknown quantity at this point
d-link bridge
so i have been fighting the new dlink unit since the beginning of the season. to my knowledge i have it set to the settings that FIRST has told us. however i still cant see the bridge as a wireless network (i am in AP mode as it told me to be) i am still unable to see or connect to the D-Link when it is not hard-wired. any ideas???
thanks
Unread 05-02-2011, 10:16
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: d-link bridge
Are you trying to use the radio as an access point or as a bridge?
Unread 05-02-2011, 10:24
Re: d-link bridge
Did you look at the Classmate wireless settings to see if the IP address is correct?
Unread 05-02-2011, 10:34
jackdawg's Avatar
AKA: Wyatt Cerilli
FRC #1307
Re: d-link bridge
i managed to fix it. the settings told me to set it to the 5ghz band but i think that if for the 2011 netbook. set it to 2.4 and now it works.
thanks anyway
Unread 05-02-2011, 10:40
Re: d-link bridge
Thanks for letting us know what the problem was.
Glad you solved it.
Unread 05-02-2011, 10:44
Re: d-link bridge
thanks anyway
I'm curious what part of How to configure your radio, Rev A made you set it to 5ghz. I'm sure FIRST would appreciate the feedback on how to make the document more clear, because they intend you to set it to 2.4ghz for team us as an access point.
Unread 05-02-2011, 18:22
aturczynski aturczynski is offline
FRC #0461
aturczynski is an unknown quantity at this point
Re: d-link bridge
i've been having troubles with the dlink, when trying to set it up i can get it onto the dlink page and did change the wireless setting
and i also tried changing the network settings but when i tried to save them the computer kicked me off the page and has not let me back on the dlink page
can anyone help? PLEASE?
Unread 05-02-2011, 18:33
Re: d-link bridge
Sounds normal.
When you change the DLink IP address, your PC will no longer be able to communicate with it. So the Saving settings page will never return,because it's trying to load the old IP address that doesn't exist anymore.
In addition, they wouldn't be able to communicate even at the new DLink IP address, because suddenly your PC and the DLink are on two different incompatible networks.
After you click save settings that change the DLink IP address you need to go change your PC IP address to 10.xx.yy.5 again.
Then browse to the DLink's new IP address at 10.xx.yy.1
Unread 05-02-2011, 20:41
FRC #0461
Re: d-link bridge
thanks
Unread 06-02-2011, 00:03
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: d-link bridge
The radio configuration manual said something about having the IP address of the programming computer above 10; is that not needed?
Is it necessary to go back there to change things? Or is it just in case you want to mess around with stuff.
Unread 06-02-2011, 00:18
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: d-link bridge
You just have to pick an IP that is not used by another device. A high number practically guarentees there will be no IP conflicts since cRIO uses .2, DriverStation default to .5 etc.
Unread 06-02-2011, 08:32
Re: d-link bridge
What he said.
Anything .6 and above is free and clear.
No, you're right. You'd only go back there to make sure you can see it at the new address. It gives you a warm and fuzzy feeling.
There is often some fiddling with straightening out the IP addresses on the Classmate to switch the Driver Station application between the wireless and wired networks. You have to make sure the wired network adaptor IP address is different than the wireless IP address. Only one of them can be .5
And you have to make sure the Driver Station app. doesn't keep trying to use the old one.
Unread 06-02-2011, 10:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: d-link bridge
It's kind of hard to follow the exact steps taken through this thread, but I think after you change the DLINK and COMPUTER IP addressses, you do need to switch the DLINK into AP mode, browse to the DLINK address and change the frequency of the radio to 2.4GHz.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 06-02-2011, 12:26
Re: d-link bridge
Our Driver Station likes to set itself to .9 when on the robot wireless network.
Unread 07-02-2011, 10:17
Re: d-link bridge
I just noticed that this weekend.
I wonder how it decides to do this?
Maybe if .5 is already taken? Have to experiment if Greg McKaskle doesn't tell us.
That could cause unusual problems for teams using laptops as competition Driver Stations.
Something to watch out for on practice day.
