Go to Post To me, being in FIRST is the biggest learning experience anyone can have. I want to give that experience to everyone I can, be it now or thirty years down the line. - BandChick [more]
Unread 06-02-2011, 12:27
TsUNaMy WaVe TsUNaMy WaVe is offline
FRC #3388
TsUNaMy WaVe is an unknown quantity at this point
Help Please ><
I'm new to all this 3ds max stuff, and I'm trying to render what I did but in the rendered frame view it shows me just black window. Why? T.T
Pic:
Unread 06-02-2011, 17:39
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Help Please ><
Do you have any objects at all in the view? It looks like its just a light to me, and there does not look like there is anything in front of the camera. I need a bit more information.
Scanline or mental ray?
If either of the two, make sure you are not using a scanline material when rendering in mental ray.
Unread 06-02-2011, 19:19
robertsun robertsun is offline
FRC #0488
robertsun is an unknown quantity at this point
Re: Help Please ><
It looks like your using mental ray.
Press F10 and scroll down to select render...Then change to scanline for now
Then go to the bottom right viewport..and click on "P" - that should change you to perspective
Then make an object right smack dab in the middle...press F9 and you should see something
report back what happens
Unread 06-02-2011, 23:17
DaveC DaveC is offline
None #0250 (The Dynamos)
DaveC will become famous soon enough
Re: Help Please ><
Is there anything in your "Perspective" viewport? The Rendered Frame Window indicates you're rendering the "Perspective" viewport, but all we can see in the screen-shot are the "Top" and "Camera01" viewports.
Unread 07-02-2011, 00:14
FRC #0488
Re: Help Please ><
a tip:
to maximize/change views...click on the window and press alt+w
*above post, yes he has the standard quads
