Go to Post The possibilities for zip ties are endless. - Elgin Clock [more]
Unread 06-02-2011, 02:06
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Festo VUVG Problems
Our team has a Festo double pneumatic valve (VUVG-L10-B52-T-M7-1P3), and we didn't get a wiring/instruction sheet with it when we got it (previous FRC season). We have other solenoid valves connected to the solenoid breakout, that is wired to the PD board, supplying the solenoids with 12v. Do we need another solenoid breakout on the c-Rio (is this legal?), or is there some other way to wire the solenoid? A wiring/tubing diagram, along with helpful tips would be appreciated. Thank you!!!
Unread 06-02-2011, 08:42
Re: Festo VUVG Problems
That Festo solenoid does need 24v to operate.
The only legal way to wire it is through another solenoid module running at 24v connected to the two spare terminals on the PD's 24v output.
You are allowed a second solenoid module (slots 7 & 8).
VUVG-L10-B52-T-M7-1P3 Quick Summary
wiring photo
Make sure you tighten the fittings with an allen key.
Unread 06-02-2011, 13:20
AKA: Ty
Do the two solenoid modules (for 12v and 24v) go into ports 7 and 8 of the c-Rio?
Unread 06-02-2011, 13:24
Yes, slots 7 & 8
Either or both can be used.
