Go to Post You earn what you work for. - Akash Rastogi [more]
Unread 05-02-2011, 06:38
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Update!
Originally Posted by rsisk View Post
Was this officially announced somewhere? I thought I was paying close attention to the information flood
I'm sure the official email from FIRST has announced this by now. But as Joe Ross mentioned, you would see a message on the Getting Started Window of LabVIEW. It's not uncommon to see this message before the official email. I added this hook to the Getting Started Window, so LabVIEW users get reminded. It pings ni.com once a day for new updates, so you find out about them almost as soon as we post them. One day we aspire to post updates and have the release dates correct too
Doug Norman
Unread 05-02-2011, 09:22
Joseph W. Horth Joseph W. Horth is offline
FRC #0280
Joseph W. Horth is an unknown quantity at this point
Re: Update!
The updated labVIEW File caused my labVIEW to not work anymore. When I open it up and hit launch it says unable to open resource files and then closes.
What happened and how do I fix it?
Unread 05-02-2011, 10:14
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Update!
I did the install on 2 laptops.....LV comes up on one, not the other. The same error! 'Unable to open resource files'
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 05-02-2011, 12:55
Re: Update!
I updated my copy on the one laptop I have with me and it worked -- meaning I have little to debug with.
John, can you compare the procedure on the two laptops? Do you think it was a difference in the laptop or in the install steps?
Can you easily compare the results? Inside Program Files/National Instruments/LabVIEW 8.6/resource, there should be 95 items according to my installation. Do you see something obviously wrong?
Thanks in advance.
Greg McKaskle
Unread 05-02-2011, 13:21
Jon236's Avatar
AKA: Jon Mittelman
Re: Update!
I copied the entire resource subdirectory over to the afflicted laptop and got a Win7 "Program Has stopped working" with the following details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
Application Version: 8.6.0.4002
Application Timestamp: 4cb70867
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdbdf
Exception Code: c06d007e
Exception Offset: 0000b727
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional Information 1: cba5
Additional Information 2: cba57985d4dfc600ca12eaab7140e875
Additional Information 3: 7cb7
Additional Information 4: 7cb7f00025d289dc6d0ac96eb597182c
Jon Mittelman
Unread 06-02-2011, 10:17
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Re: Update!
Do we need to reinstall the Utilities update after the 3.1 LV update?
Unread 06-02-2011, 10:41
Re: Update!
I do not believe so. I simply did the update and my machine seems fine. I can use the wizard to build a new sample, and I see the new examples that were added. I don't have a cRIO at home, so I can't test that part.
I believe the utilities is mostly the vision tools.
Greg McKaskle
Unread 06-02-2011, 14:03
Jon236's Avatar
AKA: Jon Mittelman
Re: Update!
I solved our problem with a complete NI uninstall, followed by reinstalling everything! Worked fine! (whew!)
Jon Mittelman
