Go to Post JVN, thanks for working with me. You will make a great MC anywhere. Folks, he actually loosened up and fit right in. - Steve W [more]
Unread 05-02-2011, 14:51
Emilys75's Avatar
Emilys75 Emilys75 is offline
FRC #3711
Emilys75 is an unknown quantity at this point
Exclamation Limit Switch and Button
I am a programmer for Team 3711 (Trout Lake Mustangs) and want to know if I can have a Limit Switch AND a Button. We have the joystick trigger running a cylinder but want a Limit Switch in series with the trigger. Is that possible to have (switch and trigger)? Most likely this will be two case statements in series. If so, I need help please. P.S. If it is possible, can you post your Vi so I can download it to se what to do?
Thanks, Emily.
Unread 05-02-2011, 16:44
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: Limit Switch and Button
So you want to run the piston only when the limit switch and button are pressed? could you explain what you want the limit switch and the button to do?
ex. piston fires only when both limit and button are pressed
ex. piston fires when limit is not pressed but button is
Expect the best, Prepare for the worst
Unread 05-02-2011, 21:36
It sounds like you want to do this in LabVIEW. You might be interested in the boolean functions such as AND and OR. You can make it so that you need two simultaneous conditions in order to trigger an action.
Unread 06-02-2011, 14:37
Bill McKinney Bill McKinney is offline
Bill McKinney is an unknown quantity at this point
Thanks for your responses. Our team is now actually running a FP motor off the x-axis of a second joystick and needs a limit switch so we don't swallow our lead screw (the cylinder got used elsewhere.)
We're going to mess with this now, but I think the and statement is going to be the answer. The trick will be to have the limit switch stop travel in one direction but still make the reverse (retracting) motion of the motor available in order to unswitch the limit switch lever.
Unread 06-02-2011, 15:05
AKA: Jon
For making the limit switch stop the motor only one way you want the in range and coerce function found in the comparison pallet. This will allow you to set the upper limit or lower limit to zero when the limit switch is pressed depending on what way you don't want the motor to spin (upper is positive and lower is negative direction)
Unread 06-02-2011, 18:58
After considerable thrashing at the in range and coerce icon I'm unable to set the limits. I see the (apparent) array in the NI example but don't see how to set the constants.
And does this function occur within a true / false case structure controlled by the limit switch DI?
I'm giving up for the duration of the superbowl................
Thanks for any leads, or example code or links to same.
Unread 06-02-2011, 19:05
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
One way to do it is to use Select nodes to change the limit for the In Range and Coerce between 1 or -1 and 0 if the switch is pressed.
EDIT: You should make sure to right click on the In Range and Coerce function and check that both "Include Upper Limit" and "Include Lower Limit" are checked.
Unread 06-02-2011, 19:26
I think your DIO checks are reversed...
The DIO's are True by default and False when a switch is pressed.
Unread 06-02-2011, 19:30
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Whoops! Right you are. I'll fix up the image right now.
EDIT: Image should be fixed now.
Unread 06-02-2011, 19:41
Well, it would have worked the other way as long as the limit switches were wired to be Normally-Closed.
But it looks good now for Normally-Opened, like most people tend to automatically think of a switch.
Unread 09-02-2011, 06:21
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Bill,
If you are only limiting in one direction, you can just wire a constant -1 to the side you aren't limiting of the "In Range and Coerce" VI. No need to check the switch or use the select statement.
Unread 09-02-2011, 12:26
Hah, that's classic. We're just about to get the second limit switch hooked up and were starting to figure how to get both in one section of code. You solved that problem of course at the same time you pointed out my extra work on the last one. I should have noticed the two different switches in your example.....
I think I'll delete my other post with the misleading code.
Thanks again, nice glacier point pic by the way.
