Go to Post What is this sleep you all speak of...if it wasn't in the KOP than it is not allowed to be used :D - Wayne Doenges [more]
Unread 06-02-2011, 14:39
mjbrauck mjbrauck is offline
FRC #0768 (Techno Warriors )
mjbrauck has a spectacular aura aboutmjbrauck has a spectacular aura about
Preloading uber-tubes
So my team has constructed a claw to hold and place tubes during a match that uses a window motor. The problem is that the window motor cannot be back-driven so loading an uber-tube for autonomous requires it to be powered closed. we considered wiring a switch into the circuit so the claw could be opened and closed without connecting the OI, but have been unable to resolve the debate over this being allowed by the wiring rules. What is the best / legal way to handle this situation?
Unread 06-02-2011, 14:48
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Preloading uber-tubes
The switch will almost certainly be illegal.
I'd say you have two options:
1. If your claw is at all flexible, you could just push the ubertube on to it. Since both the tube and your claw could deform, that would accomplish the goal. This is substandard, though. If this is the situation you're in, you'd also have problems removing a tube at the end of a match.
2. The more preferable solution would be a way to manually open the claw, like a pin or a spring. That way, you could open the claw without a motor for the start of the match, and be able to remove tubes at the end of a match.
If you can provide a bit more detail about your mechanism, I think the folks here will be able to better help you.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 06-02-2011, 14:57
phoenix_fire's Avatar
phoenix_fire phoenix_fire is offline
FRC #2489 (Insomniacs)
phoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the rough
Another thing you could do is leave the claw open for pre-loading and have the robot close it first thing in autonomous.
FRC 2489 Insomniacs
FTC 548 & 596 Geek Squad and Transformerz
Unread 06-02-2011, 15:00
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
There is the option of Tethering your robot to manually open the claw before the match and sitting an ubertube in it, then at the start of the match, the claw automatically shuts. This solution is really Dependant on the orientation of your claw and how much movement your robot will be subject to after the tube is inserted and before the claw closes.
Whoops, Phoenix Fire beat me to the post.
One more thing to pursue is asking the Q/A when you're given the Ubertube for preload. In some previous games, you were given the game piece to preload prior to placing your robot on the field, which allowed enough time to tether and load the game piece. I don't know if this will happen this year though.
-Dustin Benedict
Unread 06-02-2011, 15:04
It would alter the power flow, which is not allowed.
Just remember: the rule is "in contact", not "in possession". All you need to do is make sure you're in contact.
Unread 06-02-2011, 15:29
Ok so the plan the team came up with today is to have a set of disconnects between the victor and the speed controller and have a small battery wired to a switch and a set of disconnects(not part of the robot). so when needed we could unplug the motor and drive it individually then plug it back in for the match. I told them this might be considered an alignment device what are your thoughts?
Unread 06-02-2011, 15:34
Do you mean between the speed control and motor? I don't think this would be considered an alignment device.
The one thing to worry about though is how long it would take you to do this. If it takes a significant time, they might ask you to change it so that the matches aren't delayed.
If you are worried, ask the Q/A.
I still think a small piece of code at the beginning of autonomous to close the claw would be easier.
FRC 2489 Insomniacs
Unread 06-02-2011, 15:37
You're getting power from a device that is not the onboard 12V battery.
You're modifying the power pathways of the robot.
You could easily forget to plug the motor back in.
You're using special equipment on the field that isn't needed for a disability.
You have two speed controllers controlling one motor (victors are speed controllers).
At least three of those are legality issues.
Put some other form of claw-opener on board. Or, start with a slightly open claw if that'll fit in the box.
Unread 06-02-2011, 22:24
Well The Power supply and pathway would not be during a match so those should not be an issue, and the is no need for two speed controllers at anytime.
The additional equipment on the field is a valid concern but my interpretation of the last update was that applied to the alliance station and this device could be left on the robot cart.
I'm not actually with the team this year but as they explained it to me the claw folds into the edge of the robot frame in the starting configuration and as such can't be left open.
Unread 06-02-2011, 23:42
Mr B's Avatar
Mr B Mr B is offline
AKA: Andy Bradley
FRC #0233 (The Pink Team)
Mr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to all
Have you tried just squeezing the tube into the claw? Even filled tubes are a little squishy.
Unread 07-02-2011, 00:35
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
deflate the tube a little put it in, then blow it back up?
Unread 07-02-2011, 08:09
thefro526's Avatar
Mentor for Hire.
This is a bit questionable. I can't think of any rules off of the top of my head, but I'm sure someone will interpret it as a violation of the rules. I'd ask this in the Q&A if you're planning on doing it.
Also, there are still two weeks left until ship. If you're robot is far enough along that you've begun autonomous testing then you probably have enough time to redesign or modify the claw in such a way that you can easily pre-load an ubertube.
-Dustin Benedict
Unread 07-02-2011, 09:08
GaryVoshol's Avatar
Cogito ergo arbitro
Maybe so, but how are you going to pass inspection? That's not done on the field during a match either.
(since 2004)
Unread 07-02-2011, 11:09
JosephBurns35's Avatar
JosephBurns35 JosephBurns35 is offline
AKA: Joseph Burns
FRC #2487 (Mechanical Animals)
JosephBurns35 is an unknown quantity at this point
Send a message via AIM to JosephBurns35
depending on the specifications of your claw within the rules, the easiest thing to do would be to have a hinge with a pin so you can open the claw a little then close it. or like other people said just put a small piece of code in to close the claw as soon as the robot autonomous starts.
Unread 07-02-2011, 11:52
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
<R48> says your robot cannot have an alternate means of powering a motor
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
