Go to Post i met ANDY BAKER and D.J... they are awesome! - Arefin Bari [more]
Unread 06-02-2011, 15:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Making Joystick buttons control moters
Here are two similar, common ways to do this in Labview. The first way uses two Select statements and allows you to later change the motor power in both directions if you decide you don't want full power. You can also replace one of the select statements with a Boolean to Integer conversion.
ID:	10006  Click image for larger version
Unread 06-02-2011, 15:17
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
I will give this a try and see if it does what i want it to. Thanks
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 07-02-2011, 21:03
Slothbron's Avatar
AKA: Nathan
Just got done with robotics meeting and this worked great just what I needed.
MRT 3216
