Go to Post What we may be looking at is a confusing situation and that can be confusing. - JaneYoung [more]
Unread 05-02-2011, 17:27
tjakowenko tjakowenko is offline
AKA: Tom Jakowenko
no team (Pirates of the Pythagorean)
tjakowenko is an unknown quantity at this point
how do you code a servo to run continuously
We are using a servo to move an arm and want to command the servo to turn until triggered to stop. We're not sure how to do this using either set() or setAngle. Those commands will move the motor a fractional rotation, but not spin continuosly. Can someone provide a little insight as to command a servo from a pwm output to turn continuously, at different rates of speed and in different directions?
Thanks in advance...
Unread 05-02-2011, 19:03
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: how do you code a servo to run continuously
There are 2 types of servo's,
Standard ones, and Continuous rotation servos.
Standard servos can only do ~180 degrees of motion.(some have more range some have less)
so each PWM value corresponds to a position of the servo horn.
Continuous rotation servos, as the name implies, can rotate continuously. Each PWM servo corresponds to a rotation speed.
There is no way of making a regular servo rotate continuously.
-Borna Emami
Team 0x27
Unread 05-02-2011, 19:10
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
well there are actually ways to modify the servo to rotate continuously.
Unfortunately due to <R47>, you may not legally modify a servo.
however, you may infact be able to find a continuous rotation servo on servocity.com or other sites that meets the 4W power requirements.
Good luck
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 06-02-2011, 15:28
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
http://www.wbrobotics.com/javadoc/ed...ilibj/PWM.html
My team was having a similar issue. We decided to replace the continuous servo with a motor, but we had an untested idea to program a continuous rotation servo. I believe that there is a setSpeed(double speed) method in the PWM class, which the Servo class extends. If there isn't one, you'll have to play around with setRaw(int value). This is the code I found in the library itself:
final void setSpeed(double speed) {
        // clamp speed to be in the range 1.0 >= speed >= -1.0
        if (speed < -1.0) {
            speed = -1.0;
        } else if (speed > 1.0) {
            speed = 1.0;
        // calculate the desired output pwm value by scaling the speed appropriately
        int rawValue;
        if (speed == 0.0) {
            rawValue = getCenterPwm();
        } else if (speed > 0.0) {
            rawValue = (int) (speed * (getPositiveScaleFactor()) +
                    (getMinPositivePwm()) + 0.5);
        } else {
            rawValue = (int) (speed * (getNegativeScaleFactor()) +
                    (getMaxNegativePwm()) + 0.5);
        // send the computed pwm value to the FPGA
        setRaw(rawValue);
This method is actually meant to be used with speed controllers, but in theory it should work with a continuous rotation servo. Once again, we've never tested this, so it's up to you whether or not you want to try it. If you do, please post the results as I think it could benefit a lot of people.
Good luck!
Unread 06-02-2011, 22:00
AKA: Tom Jakowenko
Thanks for the insight. We have been able to usine the HiTech motor on a application that only move 120 degrees.
