Go to Post Dear Mr. Lavery, Congratulations. For the fourth year running, you have successfully ruined my Christmas holiday with your untimely release of a most obfuscating, but no less tantalizing, hint. - dubious elise [more]
Unread 06-02-2011, 17:45
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Number of Analog Input Channels
When defining analog input channels for Gyro's in LabView, the module is set to slot 1 and the channel selection only allows you to select one of two channels (AI 1 & AI 2). On the module though, there is 8 channels of input. I believe one of them is dedicated to battery voltage, but where are the other 5 channels?
OK, I just looked into this further. This seems to only be an issue with the Gyro vi's. When you setup a generic Analog Input channel, you can select all 8 input channels.
So I guess life is good as long as the gyro lives in the first two channels. Is this a known bug in LabView?
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 06-02-2011, 17:50
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Number of Analog Input Channels
I believe only the first two channels have accumulators configured in the FPGA.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 06-02-2011, 21:03
It's not a bug. It's a requirement due to the configuration of the FPGA. Only the first two analog channels are capable of being used as gyro inputs.
