Go to Post (Don't you hate it...) "when... no more buttons can fit onto your clothing at competitions?" - mcb [more]
Unread 06-02-2011, 18:09
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
AM sprocket out of stock
http://www.andymark.com/ProductDetai...ctCode=am-0057
How long does it usually take for AM products to get back in stock? We need one!
Unread 06-02-2011, 18:12
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Re: AM sprocket out of stock
That is a question best left to andymark. If you can afford the weight, you can get a steel one from McMaster PDQ
success is not hocus posus, it's focus focus
Unread 06-02-2011, 18:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Vex Pro also has a sprocket of this size:
http://www.vexrobotics.com/products/vexpro/mechanism-sprockets.html
They have larger sizes as well.
Kettering Motorsports
Unread 06-02-2011, 18:22
AKA: Brandon Liatys
Reason we wanted the AM one is because it has the hubs, with the bearings and all to go with it
Does vex have this?
Unread 06-02-2011, 18:23
ptitchener ptitchener is offline
FRC #3205
ptitchener is an unknown quantity at this point
These were out of stock about a week ago and then came back in stock for a short period of time. From the time that I checked and saw that they were out of stock to the time that they came back in stock was only 2 or 3 days, but I don't know how long they were out of stock before I looked. Seeing as the Vex-pro ones are in stock, those would probably be the best choice.
Unread 06-02-2011, 18:41
apalrd's Avatar
More Torque!
VRC #3333
Both the Vex Pro and AndyMark sprockets use the same 6-bolt mounting pattern (which, by the way, has been very common in FIRST for many, many years).
The Vex Pro sprocket has a bore of 1.125"
The AM one linked has a bore of .875"
AM also has one with a bore of 1.125"
Any of AndyMark's bearings with an OD of 1.125" will work with the Vex Pro sprocket.
Unread 06-02-2011, 19:47
AKA: Brandon Liatys
So the diameter of how the holes in the hub are layed out is the same as the holes in the sprocket? Awesome! thanks guys
Unread 06-02-2011, 20:00
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Those dimensions are all correct, but only deal with the bore (the big hole in the middle of the sprocket.)
What you want to match up is the bolt circle diameter. If the 6 holes for mounting screws were placed on an invisible circle, the diameter of said circle would be the bolt circle diameter.
That 60 tooth sprocket has a bolt circle of 1.875". Now, VEXPRO doesn't list the specs of its sprocket, but I am pretty darn sure it's also 1.875". Don't take my word for it though.
