Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 06-02-2011, 18:15
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
CAN Jaguar error
I did a search, but couldn't find anyone who had the same error # we encountered. This is our exact error:
Error: status == -44087 (FFFF53C9) in getTransaction() in C:/windriver/workspace/WPILib/CANJaguar.cpp at line 425
We're running image v27 with the Black Jaguar Serial Bridge plugin.
Any help would be much appreciated.
Here is the initialization code for the CAN Jaguars:
 CANJaguar *leftJag;// CAN attached Jag for the Left1 motor **** 3
	CANJaguar *rightJag;// CAN attached Jag for the Right1 motor **    2
        CANJaguar *leftJag2;// 								    4
	CANJaguar *rightJag2;// 							    5
        leftJag = new CANJaguar(3);
	rightJag = new CANJaguar(2);
	leftJag2 = new CANJaguar(4);
	rightJag2 = new CANJaguar(5);
We are currently using the TankDrive() function to run drive the motors.
Unread 06-02-2011, 19:34
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: CAN Jaguar error
Well, you'll need to post some of your code. At least the portions of it that deal with CAN. Usually, this means your code creates a CANJaguar with a number that isn't on the actual robot.
GSR Dean's List Finalist 2011
Unread 06-02-2011, 21:05
Eric24's Avatar
I updated my original post with the pertinent robot code.
Unread 06-02-2011, 21:10
AKA: Matt Soucy
Sadly, this doesn't help much by itself.
You're sure that all the jaguars are present and hooked up to the robot?
Unread 06-02-2011, 21:14
Eric24's Avatar
Yes, all the Jaguars have the correct ID numbers and are on the robot. Something I should have noted earlier is the fact that the error doesn't prevent the robot from working. The robot still drives, it just has some jitters whenever this error occurs, which is usually sparse enough to not be an issue. There have been times where they have popped up about once a second, which then made it impossible to drive.
Unread 08-02-2011, 03:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
    static final int ERR_JaguarCANDriver_TimedOut	=	-44087;
This could be an issue with the terminators on your CAN bus.
-Joe
Unread 08-02-2011, 11:51
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
We had the same problem. You are sending too much signal to the Jaguar, and the CAN Bus is lagging trying to handle it all.
Set your Wait() time in your main loop to 0.05 seconds. If that doesn't work, try 0.1. That should slow it down enough to process all the data.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 10-02-2011, 18:14
Eric24's Avatar
Thank you for your responses. I'll finally have a chance to check our terminator plug tonight since its our first build day this week. The wait time suggestion also sounds like a very good idea. I'll test both of these tonight and give an update.
Unread 10-02-2011, 21:28
Eric24's Avatar
Re: CAN Jaguar error [Solved]
I figured out that the issue was caused by running the smart dashboard because it took extra time to send the data to the dashboard. I simply commented out the dashboard code and the original wait time worked well. I might be able to modify the wait time for using the dashboard or set up a semaphore system, but it works well enough for now. Thanks for the help!
