Go to Post First check for any bind in the transmissions, especially chain. Next, check to see if the motors are O.K. Use code as a last resort. - Paul Copioli [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 03-11-2002, 22:38
Dstiebel Dstiebel is offline
#0180 (Jag-Wires)
Dstiebel is an unknown quantity at this point
pneumatic part wanted
There should be a centerblock valve in the kit. The ones they got in there now, the spool stays where it is and keeps the actuator closing or opening even after the button is released. A center block valve returns the spool after the button is released. This way the actuator can be stopped at any point, not just 100% out or 100% in. THis part should be included in next year's kit.
Unread 04-11-2002, 02:21
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Good Idea
I like this idea and we will definitely look into it. For this year, recall that Dave Johnson showed us a circuit at the SMC Pneumatics workshop where, by using 2 DCV's together, you could accomplish the same thing (stop a cylinder in mid-stroke). The output of one DCV became the input of the other and I believe a port on each DCV had to be blocked.
pneumatic cylinder part numbers Ed Crammond Pneumatics 0 14-02-2003 19:27
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
Pneumatic Parts Part 2 HK_SRT_LDR_A OCCRA 1 16-10-2001 06:12
