Go to Post Okay guys I am enabling the robot. Honestly I have know idea what it is going to do. SO MOVE!! - JulieB [more]
Unread 06-02-2011, 21:52
divisionByZero0's Avatar
divisionByZero0 divisionByZero0 is offline
Hexadecimal Hacker Droid no. 0x2328
FRC #0498 (Cobra Commanders)
divisionByZero0 is an unknown quantity at this point
Exclamation Multiple .cpp files in Windriver
The basic structure of our team's code was to have multiple .cpp files in the same project. Each .cpp was a custom Class for each component for our robot.
The problem was that our robot will refuse to load its own code.
My theory about this was the compiled .o files were not compiled in the correct order in the .out program for the CRIO's bootloader to recongize our main robot's code. Does anyone knows if the .cpp file for our main robot codes should be compiled before or after every other .cpp file? Or does the order of how each .cpp into the .out code shouldn't matter?
Unread 06-02-2011, 22:23
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: Multiple .cpp files in Windriver
Normally, the .cpps can be compiled in any order, since they'll all be linked together in the end.
GSR Dean's List Finalist 2011
Unread 08-02-2011, 03:27
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It is also true of the cRIO. The linker runs after each file is compiled. Any unresolved symbols are resolved by the loader at runtime. If the loader can't resolve them, then you get an error.
-Joe
Unread 08-02-2011, 07:00
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
If you haven't already, use the "target console" in windriver or the serial output on the cRio to find out what symbols aren't loading.
Make sure you're using matching versions of the cRio image (v27, for example) and WPILib.
Make sure that all your CPPs are added to windriver and are actually getting compiled (easy test: insert compile errors in them and see if you fail to build your project). Having a definition in a .h file but forgetting to include the cpp will allow you to compile, but it'll fail once it is on the robot.
Unread 10-02-2011, 00:19
Unhappy Re: Multiple .cpp files in Windriver
Thanks for the advice...
That problem was easily resolved....
..... but now we have a new problem
Our team-coded classes are failing to initalize some components.
Each time these components are called, The cRIO freaks out and
reboots it self. So please, just a few more questions:
How "Bug-less-ly" can you initalize a WPILib C++ object via.......
Object i.e: Victor myVictor(...)
vs.
Pointer i.e: DigitalInput* myDI = new DigitalInput(...)
What are all the possible program exceptions to look
for that relates only when initalizing the object?
If we were to put them in a custom C++ class that
our main robot will use, of which that custom class will hold all
of the required group of electronic objects of the special component
on the robot that custom class is made for; What would be a nice,
error/exception free example for this? (Sorry if you see this as a run-on)
Our team has the recent updates for Windriver, the cRIO, and the
Driver Station. So we don't think those shouldn't be the problem.
Please, help us.....
Thank you all in advance,
And thank you everyone else who helped us on this topic so far.....
498 Student Programmer: 2008 to 2011
498 Hemi-mentor: 2011 to ....
If all else fails, multiply both sides by zero to neutralize the equation.
Unread 10-02-2011, 07:28
Bongle's Avatar
What we typically do is instantiate all our component pointers in the Robot constructor, then pass them into the sub-controller classes.
Example: Let's say my robot class is Robot2702
class ArmController2702
public:
ArmController2702(Victor* pClaw, Victor* pArm, Encoder* pArmEncoder) : m_pClaw(pClaw), m_pArm(pArm), m_pEncoder(pEncoder) {}
class Robot2702
public:
Robot2702()
clawMotor = new Victor(1,2);
armMotor = new Victor(3,4);
armEncoder = new Encoder(5,6,7,8);
armController = new ArmController2702(clawMotor, armMotor,armEncoder);
void OperatorControl() {}
void Autonomous() {}
Checks:
-It's a good idea to pass objects in or instantiate them in the constructor. That way, you know they're there before you start using the class.
-To figure out what's going on, I believe there is a function you can use called wpi_fatal which will halt execution. You could use it like this
if(armEncoder == NULL) wpi_fatal("oh no, our arm is missing!");
then watch the output in the console to see what's going on
-Make sure your battery is full. A low battery can cause the robot to reset once a motor draws current and drops the voltage too low.
Unread 14-02-2011, 23:42
Talking Re: Multiple .cpp files in Windriver
Works perfectly!!!!!!
Thank you so MUCH
