Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 07-02-2011, 01:50
Hellfeier675's Avatar
Hellfeier675 Hellfeier675 is offline
FRC #0675 (Tech High Robotics Syndicate)
Hellfeier675 is an unknown quantity at this point
Air Tanks
My team has spent a great deal of time reading the rules over and over and came to the conclusion that using a different tank for air storage would in fact be legal. The specifications are well over that of FIRST's regulations specified in the rules and it is a COTS item.
Is this right or are we pushing the rules a bit?
-"Guys it's so inconvenient, Delphi is down at 3 am.... Hey I was bored last night!"
Unread 07-02-2011, 02:05
implosionprez's Avatar
implosionprez implosionprez is offline
AKA: Ty
FRC #2484 (Team Implosion)
implosionprez is an unknown quantity at this point
Re: Air Tanks
The GDC did say that there is not limit to the amount of air stored this year. As long as it's a COTS part, it's legal, according to rule R66, updated in Team Update #2.
Team Update #2 makes doesn't give a limit to the number of pneumatic storage tanks a team can use. This makes it sound like teams can use an unlimited number of storage tanks on the hostbot. Is this true?
GDC: Correct, there is no explicit limit on volume of stored air permitted on the ROBOT
Unread 07-02-2011, 02:06
Re: Air Tanks
Thank you! For some reason my team hasn't printed out the revisions yet ... we should probably do that
Unread 07-02-2011, 08:12
Re: Air Tanks
R66...
K. Pneumatic storage tanks.
There is no limit on size or volume as long as all other rules are satisfied. If you are using an unknown tank, be ready to show a specification sheet, listing working and burst pressures for your pneumatic components.
