Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 07-02-2011, 09:34
konk25's Avatar
konk25 konk25 is offline
AKA: Kishan Shah
FRC #2935 (COUGARS)
Team Role: Student
konk25 is an unknown quantity at this point
Minibot Aluminium
Rule <R92> specifies that shapes of aluminium that we can use, do you still think that we are allowed to make parts out of aluminium sheet?
We are going to build our final design now and we dont want to run into problems.
Unread 07-02-2011, 09:46
Patrick Seeney Patrick Seeney is offline
Patrick Seeney
FRC #0469 (Las Guerrillas)
Patrick Seeney is an unknown quantity at this point
Re: Minibot Aluminium
The way I interpret the rule is that those are the materials you are allowed to use. Therefore, as long as you use those materials, you can make them in to whatever you need.
Unread 07-02-2011, 10:00
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
<R92> The following items are the only permitted materials for use on the MINIBOTS:
H. Raw welding rod, aluminum
sheet
, 90° angle, u-channel, tube,
bar, that is not sold in pre-perforated or pre-punched form.
According to this rule, you are allowed to use Aluminum Sheet and modify it how ever you like, as long as it started as Raw Sheet and not a pre-punched form.
-Dustin Benedict
