Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 07-02-2011, 11:56
kushvp kushvp is offline
FRC #0467 (Shrewsbury Colonials)
kushvp is an unknown quantity at this point
pic: Teaser - Team 467
Unread 07-02-2011, 11:57
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: pic: Teaser - Team 467
Keep in mind <R37.H>
<R37> The 12V battery, the main 120-amp circuit breaker, and the PD Board shall be connected as shown in Figure 3-4. In particular:
A. The battery must be connected to the ROBOT power system through the use of the Anderson Power Products (APP) connector.
B. The APP connector must be attached to the battery with either the copper lugs provided in the KOP or appropriately-rated and -sized lug connectors.
C. The battery terminals and the connecting lugs must be insulated with shrink tubing and/or electrical tape.
D. The main 120-amp circuit breaker must be directly connected to the hot (+) leg of the ROBOT-side APP connector. Only one 120-amp main circuit breaker is allowed. This breaker must not be bypassed.
E. The PD Board must be directly connected to the APP connector and main 120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit breaker.
F. Each primary power connection between the battery and PD Board must be made with #6 AWG (4.11mm) red and black wire or larger.
G. The 120-amp circuit breaker must be quickly accessible from the exterior of the ROBOT.
H. The PD Board and all circuit breakers must be easily visible for inspection.
I don't seen any issue with it right now as it is easy visible right now turned on its side. I don't know what the rest of the robot will look like, but if it's difficult to flip over during inspection (due to size constraints, etc...) then you may have issues.
There are many inspectors browsing this forum that may be able to give you better advice.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-02-2011, 11:59
Aren_Hill's Avatar
Build Nifty Things
If i were inspecting it I'd want a look underneath anyway but that might be the drive systems fault
Tipping the robot on its side for inspection is no big deal
A guy who likes robots.
Unread 07-02-2011, 12:14
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Last year, we had our PD board in quite a similar position, only more buried. Aside from comments on horrible wire management (we fixed that before Atlanta), we passed inspection.
I know every inspector is different, and this is a new year, but I don't think that will be an issue.
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 07-02-2011, 12:24
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
You sir, have a lot more confidence in screws holding the cRIO from falling to the ground then I would.
Unread 07-02-2011, 12:45
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
not just that but the cards holding themselves in the cRIO is what sticks out to me. otherwise its a very clean wiring system.
Bacon
Unread 07-02-2011, 12:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
And a lot more confidence than I would have about driving over something on the field (like loose parts that fell off another robot - even just a screw) and kicking it up...
Unread 07-02-2011, 14:27
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
That cRIO makes me cringe.
HIGHLY recommend changing that
Unread 07-02-2011, 14:47
We are considering on putting a piece of .0625 or .125 lexan over the cRio and sandwich it in with the modules installed, to avoid any field shrapnel hitting it and modules falling out.
Unread 07-02-2011, 23:11
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Apparently nobody here has seen 1350's 2010 crio mount, It was mounted on the double walled lexan side panels. That might not seem that bad, but sometimes, due to our interesting configuration*, that was on the bottom. Additionally, the side panels were only supported by threaded rod. To top it all off, our overpowered ball control mechanism had a tendency to lift the robot up and over the balls, placing them under the robot, after which our driver would attempt to dislodge it by any means necessary. There was at least one match where I wondered how the crio was not damaged by such occurrences.
*It was fully symmetrical, there was no 'up'
