Go to Post Fire and smoke are great if you're into Battlebots, but we like to avoid them in FIRST competitions. - [more]
Unread 02-04-2011, 08:00 PM
Twisted eric's Avatar
Twisted eric Twisted eric is offline
FRC #0581
Twisted eric is an unknown quantity at this point
Question Line tracker mix up
I'm using the base code they give us I have a problem it takes the the right sensor and the middle sensor to go completely strait
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
public class LineTracker extends SimpleRobot {
    RobotDrive drive; // robot drive base object
    DigitalInput left; // digital inputs for line tracking sensors
    DigitalInput middle;
    DigitalInput right;
    DriverStation ds; // driver station object for getting selections
    double defaultSteeringGain = 0.70; // the default value for the steering gain
    public LineTracker() {
        drive = new RobotDrive(1, 2);
        // set the MotorSafety expiration timer
        drive.setExpiration(15);
        // create the digital input objects to read from the sensors
        left = new DigitalInput(1);
        middle = new DigitalInput(2);
        right = new DigitalInput(3);
        // get the driver station instance to read the digital I/O pins
        ds = DriverStation.getInstance();
    public void autonomous() {
        int binaryValue; // a single binary value of the three line tracking
                        // sensors
        int previousValue = 0; // the binary value from the previous loop
        double steeringGain; // the amount of steering correction to apply
        // the power profiles for the straight and forked robot path. They are
        // different to let the robot drive more slowly as the robot approaches
        // the fork on the forked line case.
        double forkProfile[] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00};
        double straightProfile[] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0};
        double powerProfile[];   // the selected power profile
        // set the straightLine and left-right variables depending on chosen path
        boolean straightLine = ds.getDigitalIn(1);
        powerProfile = (straightLine) ? straightProfile : forkProfile;
        double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end
        boolean goLeft = !ds.getDigitalIn(2) && !straightLine;
        System.out.println("StraightLine: " + straightLine);
        System.out.println("GoingLeft: " + goLeft);
        boolean atCross = false; // if robot has arrived at end
        // time the path over the line
        Timer timer = new Timer();
        timer.start();
        timer.reset();
        int oldTimeInSeconds = -1;
        double time;
        double speed, turn;
        // loop until robot reaches "T" at end or 8 seconds has past
        while ((time = timer.get()) < 8.0 && !atCross) {
            int timeInSeconds = (int) time;
            // read the sensors
            int leftValue = left.get() ? 1 : 0;
            int middleValue = middle.get() ? 1 : 0;
            int rightValue = right.get() ? 1 : 0;
            // compute the single value from the 3 sensors. Notice that the bits
            // for the outside sensors are flipped depending on left or right
            // fork. Also the sign of the steering direction is different for left/right.
            if (goLeft) {
                binaryValue = leftValue * 4 + middleValue * 2 + rightValue;
                steeringGain = defaultSteeringGain;
            } else {
                binaryValue = rightValue * 4 + middleValue * 2 + leftValue;
            // get the default speed and turn rate at this time
            speed = powerProfile[timeInSeconds];
            turn = 0;
            // different cases for different line tracking sensor readings
            switch (binaryValue) {
                case 1:  // on line edge
                    turn = 0;
                    break;
                case 7:  // all sensors on (maybe at cross)
                    if (time > stopTime) {
                        atCross = true;
                        speed = 0;
                    break;
                case 0:  // all sensors off
                    if (previousValue == 0 || previousValue == 1) {
                        turn = steeringGain;
                    } else {
                        turn = -steeringGain;
                    break;
                default:  // all other cases
            // print current status for debugging
            if (binaryValue != previousValue) {
                System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross);
            // set the robot speed and direction
            drive.arcadeDrive(speed, turn);
            if (binaryValue != 0) {
                previousValue = binaryValue;
            oldTimeInSeconds = timeInSeconds;
            Timer.delay(0.01);
        // Done with loop - stop the robot. Robot ought to be at the end of the line
        drive.arcadeDrive(0, 0);
     * This function is called once each time the robot enters operator control.
    public void operatorControl() {
        // supply your own teleop code here
All i got rid of was the comments and the section of code that reverses the motors because it screwed with the wheel rotation.
I have wired it correctly according to the code is there something I'm missing
Unread 02-07-2011, 07:24 AM
warfaj's Avatar
warfaj warfaj is offline
FRC #0610
warfaj has a spectacular aura aboutwarfaj has a spectacular aura about
Re: Line tracker mix up
Try getting rid of the time and steering gain. Then add some additional cases so that you know exactly what happens when each of the light sensors are triggered.
Unread 02-07-2011, 01:59 PM
FRC #0581
thanks i will try that today after school
