Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 07-02-2011, 15:37
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Servos - Digital vs Analog - which are compatible
Hello - So I was doing some quick research to find legal servos under 4Watts when I noticed 2 types, digital and analog. As I see in the link below, the HS-322 in the KOP appears to be analog.
http://www.servocity.com/html/hs-322...rd_deluxe.html
The PWM code and wiring to the DSC creates a pulse width modulated signal to control servos as I understand it (I would have considered that a digital input, though averaged over time that creates an analog voltage). I haven't put a logic analyzer on it to see the signals yet, but I am curious the difference between analog and digital servos, and where in the FRC KOP info it defines which type of servo is compatible (if it does).
So are digital input servos compatible with FRC SW and the DSC? Or just analog servos?
http://www.servocity.com/html/hitec_servos.html
Thanks
