Go to Post Honor is doing the right thing when nobody is watching. - Daniel_LaFleur [more]
Unread 07-02-2011, 16:14
Dakota Dakota is offline
FRC #2805
Dakota is an unknown quantity at this point
Minibot Battery
We need to order a spare battery for our minibot, but the spare batteries are $50. I can build an equivalent battery for $14 but it would be 1600mAH as opposed to the supplied battery's 3000mAH. Is this acceptable by FIRST regulation?
Wolfpack Team #2805
Unread 07-02-2011, 16:20
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Minibot Battery
<R92> The following items are the only permitted materials for use on the MINIBOTS:
C. no more than one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057) except the 20A fuse may be replaced with an equivalent type of lower amperage,
if it's not identical, and it sounds like it isn't, then it isn't legal.
Unread 07-02-2011, 16:21
nitneylion452's Avatar
AKA: Joe Lee
Re: Minibot Battery
<R92>
Emphasis mine.
I don't think making your own battery would be legal, in this case.
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: Minibot Battery
As stated in the rules (R92 C), it must be identical to the battery in the FTC kit of parts. Having a lower mAH rating makes this battery not identical to the one supplied in the kit. I am not on the GDC, but in my interpretation of the rules, this would not be allowed. However, if you could make one that supplied 3000 mAH, it would be identical, fitting the rule.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 07-02-2011, 16:26
FRC #2805
Re: Minibot Battery
Thank you.
Wolfpack Team #2805
Unread 07-02-2011, 16:52
Re: Minibot Battery
I emphatically disagree with that statement. It might have the same capacity specifications, but it would not be an identical part, and it would thus not follow the rule.
Unread 07-02-2011, 17:19
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
Re: Minibot Battery
Have you checked the FIRST Q and A forum?
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 07-02-2011, 22:54
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Minibot Battery
You really do not have to check the forums. Using a self-made battery is obviously illegal, and dangerous if you're not sure.
Using it for practice is fine, as long as it's safe.
Unread 08-02-2011, 01:05
Re: Minibot Battery
Dakota,
You can ask the Q&A but this rule makes all minibots use the exact same voltage/current/weight battery that has a fuse holder attached for use with known (and widely available at competition) battery charger and connector.
Unread 08-02-2011, 01:27
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Minibot Battery
Why do you need a new battery? One should be plenty enough to run the competition. 3000mAh is way overkill for a couple tetrix motors. I still don't understand why they made us use such a massive battery.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
