Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 07-02-2011, 17:13
hoosfoos1993 hoosfoos1993 is offline
FRC #0675
hoosfoos1993 is an unknown quantity at this point
Texturing Iiko Rigs for the Animation
I have imported the Iiko rigs for the animation challenge, but I can't figure out how to add the texture to the rigs so that they are their normal spotted selves instead of white. Can anyone tell me how to put the texture on?
Unread 07-02-2011, 18:23
playbass06 playbass06 is offline
"bass" as in the guitar, not a fish
AKA: Chris Schaaf
FRC #1986 (Team Titanium)
Team Role: Animator
playbass06 is an unknown quantity at this point
Send a message via AIM to playbass06 Send a message via Yahoo to playbass06
Re: Texturing Iiko Rigs for the Animation
You've got to re-link the bitmaps to the textures they use. I'm going to assume you have knowledge of the material editor and how to get around it, so here's what you do: Open up your material editor and go to the material/map browser menu (the button will say Standard by default, I don't know what the menu is technically called) and at the bottom of all the material types are the materials currently used in the scene. Select the iiko material and go to the diffuse maps they use. Select the image the map links to and find the uv_1 and uv_2 maps, wherever you saved the iikoRig folder to. I think there are two materials you have to do this with.
If this isn't clear I'll try to explain it better.
Unread 08-02-2011, 22:53
FRC #0675
That was perfect, thanks!
