Go to Post What's the point of competing if you're not going to be competitive? - davepowers [more]
Unread 07-02-2011, 17:11
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Re: Mounting an Omniwheel
The wheel fell off of the baring. No, thats how it was when it fell off. At the time, the omniwheels were not powered (we were just testing it, and intended to make it four wheel drive). And it was Frame, spacer, wheel, spacer, frame.
Unread 07-02-2011, 17:13
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
It sounds like your bearing is a little bit to small
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 07-02-2011, 17:17
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
You are putting two bearings in per wheel right? (One per side)
I've never used the omni's but i'm largely sure they work like all the other AM wheels in which you put 1 bearing in on each side.
Unread 07-02-2011, 17:18
AKA: Bryan
Originally Posted by The Troll View Post
Have You tried turning it on and off?
For risk of feeding the troll.. Please don't post unless you have some valuable insight or ability to help the discussion
Unread 07-02-2011, 17:26
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Crusaders)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Are you using the single or dualie(sp?) omni? If the single you need to purchase the bearing hub off andymark. If the dualie you need to use a flagged bearing on either side and still keep those spacers. You may also use the am sprocket spacers ie: pvc-bearing-wheel-spacer-sprocket-spacer-bearing-pvc for the single wheel.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST Hawaii Regional
-FIRST San Francisco Regional
Unread 07-02-2011, 17:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The AM omniwheel shown contains only a single bearing. You'll want at least two-bearings constraining something to a shaft -- but no more than two.
In this case, since you're using a dead-axle, I'd find the appropriate bearing to fit into whatever sprocket you've got bolted onto your omniwheel. It'll probably be an R8 flanged ball bearing and is available from AndyMark as well.
The flanges on the ball bearings constrain them axially in only one direction. You'll want to use spacers or shaft collars on the side of each bearing that faces away from the wheel to constrain them axially in both directions. Be certain that the spacer or shaft collar you use contacts ONLY the inner race of the bearing or you'll experience additional frictional losses and, perhaps, binding.
Be aware that flangeless ball bearings are not constrained axially at all in this sort of arrangement and can fall "into" the wheel. If that's the case, you can add a third spacer that lives between the wheel and sprocket, but I'd recommend getting flanged bearings instead.
--Madison--
...down at the Ozdust!
Unread 07-02-2011, 17:32
The Troll The Troll is offline
Safety Manager
AKA: Tim
FRC #3597 (Robo-Rangers (Twisted Steel and Sex Appeal))
The Troll is an unknown quantity at this point
Okay I'm Serious Now. Have you tried putting a 6 inch metal plate in the middle of the wheels. If cut right and wielded it will not hit the corners purtruding out. It will connect to the rotational device. When it spins it will hold it in place while still being able to move with reinforced steel to back it up. I hope that helps. Make sure it's small enough so you dont have it flopping like a fish.
Unread 07-02-2011, 21:19
Lead Programmer
AKA: Josh
A guy on my team says that that would be like trying to make a peanut butter and jelly sandwich with a laser from a satellite in space. Overcomplicated.
