Go to Post CAD is the oxygen for engineering. - Bharat Nain [more]
Unread 07-02-2011, 18:22
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: pic: burnt up TETRIX motor
We had the same problem, a burned out motor. I assume that it is a blown inductor. How many amps will blow out the inductor? And is there an acceptable fuse that will prevent this from happening, preferably one that fits in the battery's fuse clip?
Thanks,
David
