Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 07-02-2011, 20:23
ianonavy ianonavy is offline
Programming Mentor/Alumnus
AKA: Ian Adam Naval
FRC #3120 (RoboKnights)
ianonavy is an unknown quantity at this point
RS395-12V Motor Mount
Our team made design change requiring us to mount the smallest size BaneBots motor (RS395) to our robot. The next size up, RS540, is another viable option for us. We've searched the BaneBots website and cannot find a smaller alternative to the CIM-U-LATOR (which we've already ordered for the larger motors). Does anyone know of a way to mount the smallest BaneBot motors to an aluminum channel that will be able to arrive before the ship day?
Unread 07-02-2011, 23:27
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: RS395-12V Motor Mount
Hose clamp, my team is using it for a mini-bot deployment system and we simply dremeled to small holes in the channel and ran a hose clamp around the whole mess, the bane bots does not have enough torque to turn itself.
Unread 08-02-2011, 03:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Take a look at a hobby shop for some sort of model airplane "Speed 400" gearbox. Might work.
Unread 08-02-2011, 03:42
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
we used a Black and Decker electric screwdriver. It is super easy to pop out the motor and replace it with a BB 395, you just have to remove a couple ribs inside the housing and file a flat into motor shaft. If I remember right, they have about an 1:80 reduction.
Jason
