Go to Post That's awesome. I sort of like the smaller venues. You get to know teams on a lot more personal level. - thisOrrthat [more]
Unread 07-02-2011, 20:27
Triapod Triapod is offline
Triapod is an unknown quantity at this point
Re: PID Inputs and Outputs
Thank you for the responses. The method works -- just needed to be careful of the integral gain that caused a periodic motion.
Unread 08-02-2011, 02:39
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
I recommend removing the error wire between the Motor SetOutput and the Encoder Get. This will allow those two independent operations to run in parallel.
-Joe
Unread 08-02-2011, 09:28
-Joe
I thought to get the new encoder value right after the motor input has been sent from the PID in each iteration. I'll see if it makes a difference
Also in the image, the encoder should be started
